iiyama ProLite LE6540UHS-B1 65" 3840x2160 LED Digital Signage
Quicklinx: DKK2WS00 Mfr#: LE6540UHS-B1
See the difference with the ProLite professional signage display. Featuring a slim bezel and an IPS LED panel for exceptional color and image performance, it offers businesses an easy and effective solution to successfully help them get their message across to the clients.
iiyama ProLite LE6540UHS-B1 65" Class (64.6" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
65"
Diagonal Size
64.6"
Commercial Use
Yes - digital signage
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
4 ports
LAN
PC Interface
VGA (HD-15), HDMI, DisplayPort
AMVA3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Open Pluggable Standard (OPS) support
Speaker System
2 speakers
USB
Remote control, batteries
Voltage
Energy Class
Class B
110 Watt
Power Consumption (On mode)
165 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
272 kWh
145.87 cm x 8.16 cm x 83.47 cm
24.8 kg
Energy Class
Class B
110 Watt
165 W
272 kWh
Diagonal Class
65"
Diagonal Size
64.6"
Commercial Use
Operating System
Android OS
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
Modes
Landscape mode
Design
Fanless Design
Dimensions
Without stand
145.87 cm
8.16 cm
83.47 cm
24.8 kg
Enclosure Colour
Matte black
Display
LCD Display Technology
AMVA3
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
Commercial Features
Anti Image Retention Circuitry (AIR)
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Streaming media playback
LAN
Connector Type
VGA input , 4 x HDMI input , DisplayPort input , Audio input , RS-232 input , LAN , Infrared input , 2 x audio output , RS-232 output , Loop thru output , USB 2.0
Batteries
HDMI cable , Mini DisplayPort-DisplayPort cable , Serial cable , DisplayPort cable
Plug and Play, DDC-2B, CB, TUV Bauart, CU, DisplayPort 1.2
Power supply
Input Voltage
0.5 Watt
Width (Shipping)
165.5 cm
Depth (Shipping)
28 cm
Height (Shipping)
107.8 cm
