iiyama ProLite E2482HS-B1 24" 1920x1080p 1ms HDMI VGA DVI LED Monitor
Quicklinx: DPSTWS00 Mfr#: E2482HS-B1
The ProLite E2482HS is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 1 ms response time and 80.000.000:1 contrast ratio, assuring clear and vibrant picture quality and high contrast. Triple Input support ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The E2482HS is also equipped with two high quality stereo speakers. TCO Certified, this monitor is a reliable solution for both home and office use.
  • Full HD resolution
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • Flicker-free + blue light reduction
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reduction substantially minimize the strain and fatigue caused by flickering and blue light emittance of regular monitors.
  • ACR (Advanced Contrast Ratio)
    Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite E2482HS-B1 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
24.9 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Matte
Voltage
AC 120/230 V (50 - 60 Hz)
56.55 cm x 20.3 cm x 41.2 cm
3.4 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
DDC-2B, DDC/CI, RoHS, WEEE, PSE Mark, VCCI Class B
3-year warranty
Display Type
Energy Class
Class A
36 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology, Blue Light Filter technology
3.4 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , HDMI , DVI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - 1.5 m , 1 x audio cable - 1.5 m
Security Slot Type
Kensington security slot
Input Voltage
24.9 W
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
