iiyama ProLite B2482HS-B1 24" 1920x1080 1ms HDMI DVI VGA LED Monitor
Quicklinx: DQ5FWS00 Mfr#: B2482HS-B1
The ProLite B2482HS is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 1ms response time and 80 000 000:1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. The ergonomic stand offers height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. A perfect solution for education, local government, business and finance markets.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • Height adjustable stand with pivot function
    With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
  • Flicker-free monitor with blue light reducer function
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emittance of regular monitors.
  • Integrated speakers
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
  • Advanced Contrast Ratio (ACR)
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite B2482HS-B1 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
24.9 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Screen Coating
Matte
Voltage
AC 120/230 V (50 - 60 Hz)
56.55 cm x 23 cm x 38.65 cm
5.1 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
TUV GS, DDC-2B, DDC/CI, RoHS, WEEE, PSE Mark, VCCI Class B
3-year warranty
Display Type
Energy Class
Class A
36 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology, Blue Light Filter technology
5.1 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DVI , HDMI , Audio line-out
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - 1.5 m , 1 x audio cable - 1.5 m
Security Slot Type
Kensington security slot
Input Voltage
24.9 W
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
