iiyama E2282HD-B1 21.5" 1920x1080 5ms VGA DVI LED Monitor
Quicklinx: BPGKWS00 Mfr#: E2282HD-B1
The ProLite E2282HD is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 5ms response time and >12 000 000: 1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • Key lock
    You can easily lock and unlock the controls preventing unauthorized changes to settings you made.
iiyama ProLite E2282HD-B1 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
50.5 cm x 19.3 cm x 38.25 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, DDC/CI, VCCI Class B
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
H/V position, sharpness, input select, colour temperature, phase
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
50.5 cm x 19.3 cm x 38.25 cm - with stand
2.6 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Stand
1 x DVI cable - DVI-D to DVI-D
Input Voltage
Power Consumption (Typical)
21 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 50.5 cm - depth: 5.65 cm - height: 31.05 cm , With stand - width: 50.5 cm - depth: 19.3 cm - height: 38.25 cm - weight: 2.6 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
