The HP UPS network module allows an HP Uninterruptible Power System (UPS) to be directly connected to the network for remote monitoring and management of either a single UPS, or two UPSs in a redundant configuration. The UPS network module works with the HP power protector clients and can be configured to send alert traps to HP systems insight manager and other SNMP management programs or used as a standalone management system. This flexibility enables you to monitor and manage UPSs through the network. To facilitate day-to-day maintenance tasks, the embedded management software provides detailed system logs.
The HP UPS network module enables you to configure, monitor and manage power environments through comprehensive control of individual HP UPSs.
The UPS network module can be configured to send alert traps to HP systems insight manager and other SNMP management programs or used as a standalone management system. This flexibility enables you to monitor and manage the UPS through the network connector; the serial connector located on the front of the management module is only used for configuration. To facilitate day-to-day maintenance tasks, the firmware provides detailed system logs.
- HPE UPS Network Module MINI-SLOT Kit - remote management adapter
- Remote management adapter
- Form Factor
- Plug-in module
- 13 cm x 4 cm x 6 cm
- 460 g
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- Data Transfer Rate
- 100 Mbps
- 3-year warranty
- Designed For
- HPE R/T2200 G4, R/T3000 G2, R/T3000 G4 High Voltage, R/T3000 G4 Low Voltage, R1500 G4; UPS R/T3000 G2 Detachable Cord High Voltage, R1500 G3, R5000, R7000
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Ethernet, Fast Ethernet
- 100 Mbps
- Remote Management Protocol
- SNMP, HTTP
- 128-bit encryption
- 1 - RJ-45 , 1 x management
- Compatible Slots
- 1 x Expansion Slot
- Cables Included
- 1 x serial adapter
- Encryption Algorithm
- 128-bit SSL
- 13 cm
- 4 cm
- 6 cm
- 460 g
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 20 - 80% (non-condensing)
- Designed For
- HPE R/T2200 G4, R/T3000 G2, R/T3000 G4 High Voltage, R/T3000 G4 Low Voltage, R1500 G4 , HPE UPS R/T3000 G2 Detachable Cord High Voltage, R1500 G3, R5000, R7000
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
