HP 20-port Gig-T / 2-port 10-GbE SFP+ v2 zl Module for HP E5400/E8200 series zl switches
- Two open 10-GBE SFP plus transceiver slots
- 20 RJ-45 autosensing 10/100/1,000 ports (IEEE 802.3 Type 10 Base-T, IEEE 802.3u Type 100 Base-TX, IEEE 802.3ab Type 1,000 Base-T)
- Media Type: Auto-MDIX
- Duplex: 10 Base-T/100
- Base-TX: half or full, 1000 Base-T: full only
2.1 lb. (0.95 kg)
Dimensions (W x D x H)
10.3 x 8.13 x 1.75 in. (26.16 x 20.65 x 4.45 cm)
- HPE - expansion module - Gigabit Ethernet x 20
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Auxiliary Ports
- 2 x SFP+
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Designed For
- HPE 8206, 8206-44G-PoE+/2XG-SFP+ v2, 8212, 8212-92G-PoE+/2XG-SFP+ v2; HPE Aruba 5406, 5406-44G-PoE+/4SFP, 5406-44G-PoE+-2XG v2, 5406-48G, 5412, 5412-92G-PoE+/4SFP, 5412-92G-PoE+-2XG v2, 5412-92G-PoE+-4G v2, 5412-96G
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Auxiliary Ports
- 2 x SFP+
- 1 Gbps
- Expansion Slots
- 2 (total) / 2 (free) x SFP+
- 20 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x Expansion Slot
- Designed For
- HPE 8206 zl Switch, 8206-44G-PoE+/2XG-SFP+ v2 zl Switch, 8212 zl Switch, 8212-92G-PoE+/2XG-SFP+ v2 zl Switch , HPE Aruba 5406 zl, 5406-44G-PoE+/4SFP Rack Shippable zl Switch, 5406-44G-PoE+/4SFP zl, 5406-44G-PoE+-2XG v2 zl, 5406-48G Rack Shippable zl, 5406-48G zl, 5412 zl, 5412-92G-PoE+/4SFP Rack Shippable zl, 5412-92G-PoE+/4SFP zl, 5412-92G-PoE+-2XG v2 zl, 5412-92G-PoE+-4G v2 zl, 5412-96G zl
Aruba SFP Transceiver Module 1000Base | In Stock | £122.28 |
Aruba 10G SFP+ LC SR 300m MMF XCVR | In Stock | £385.55 |
