HPE Storageworks 81E 8GB PCI-E
Quicklinx: 6MTXWS00 Mfr#: AJ762A
The introduction of the HP PCIe 8Gb Fibre Channel Host Bus Adapters brings datacenter infrastructure components to a higher level of performance and efficiency with the ability to deliver twice the I/O performance of 4 Gb FC HBAs. An 8 Gb Fibre Channel HBA purchased today is backward compatible with 4 and 2 Gb storage networks and will protect future investments. When using storage intensive applications, such as backup/restore, database transactions, virtualization, and rich media, the increased performance of the 8 Gb infrastructure enables more rapid storage and retrieval of critical information. Finally, PCIe 8Gb FC Host Bus Adapters provide a number of features that work together to reduce power consumption, thus delivering a "green" benefit within the server.
  • High Performing Fibre Channel Host Bus Adapters
    The HPE StoreFabric PCIe 8Gb Fibre Channel Host Bus Adapters deliver twice the I/O performance of 4 Gb FC HBAs.Moving to 8 Gb technology provides the infrastructure required for the more powerful servers and data intensive applications of the future.When using storage intensive applications like backup/restore, database transactions, virtualization and rich media, the improved I/O performance enables faster storage and retrieval of data.
  • Provides Greater Efficiency in Virtualized Environments
    Ideal for the implementation of virtual servers with the power to drive multiple virtual machines.Allows a single port to acquire multiple N Port IDs, eliminating the need for additional physical ports.Datacenter administrators do not need to concern themselves with multiple requests from the virtualized servers potentially creating conflict.Improves host utilization and enhances application performance.
  • Latest Technology Supports Green Initiatives
    HPE StoreFabric 8 Gb FC HBAs have unique features in support of 'green' server technology.
HPE StorageWorks 81E - host bus adapter - PCIe 2.0 x4 / PCIe x8 - 8Gb Fibre Channel
Host bus adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x4 / PCI Express x8
Ports
8Gb Fibre Channel
16.8 cm x 6.9 cm
Cabling Type
Fibre optic
8Gb Fibre Channel (SW)
Data Transfer Rate
8 Gbps
Microsoft Windows Server 2003, SunSoft Solaris x86 10, Red Hat Enterprise Linux 4, SuSE Linux Enterprise Server 11, SuSE Linux Enterprise Server 10, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008
3-year warranty
ProLiant DL120 G7, DL165 G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G7, DL580 G5, DL580 G7, DL585 G7, DL980 G7, ML350 G6, SL160s G6; StorageWorks MSL2024, MSL4048, MSL8096, SN6000C 16, SN6000C 32; StorageWorks 1/8 G2 Tape Autoloader; StorageWorks Network Storage Gateway X3400 G2, X3800 G2
Host bus adapter
Plug-in card
Ports
8Gb Fibre Channel
Wired
Cabling Type
Fibre optic
8Gb Fibre Channel (Short Wave)
Data Transfer Rate
8 Gbps
Auto-negotiation
Expansion Slots
1 (total) / 0 (free) x SFP+
1 x 8Gb Fibre Channel (short wave) - LC multi-mode - x 2
Compatible Slots
1 x PCI Express 2.0 x4 / PCI Express x8
Low-profile bracket, 8 Gb SFP
16.8 cm
6.9 cm
Limited warranty - 3 years
55 °C
5 - 95% (non-condensing)
HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G5p Special Server, DL160 G6 Special Server, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Base, DL165 G7 Performance, DL165 G7 Special Server, DL170h G6, DL180 G6 Special Server, DL2x170h G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL4x170h G6, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, DL980 G7, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160s G6, SL160z G6, SL170z G6, SL2x170z G6 , HPE StorageWorks 8/8 (8) Full Fabric Ports Enabled SAN Switch, 8/8 Base (0) e-port SAN Switch, MSL2024 Ultrium 3000, MSL2024 Ultrium 3280, MSL4048 Ultrium 3000, MSL4048 Ultrium 3280, MSL8096 Ultrium 3280, SN6000C 16-ports Active Fabric Switch, SN6000C 32-ports Active Fabric Switch , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 3000 , HPE StorageWorks Modular Smart Array P2000 G3 FC Dual Controller LFF Array , HPE StorageWorks Network Storage Gateway X3400 G2, X3800 G2
