HPE ProCurve Switch 2510-24
Quicklinx: 551CWS00 Mfr#: J9019B#ACC
1 on order, delivery delayed
Designed to provide essential solutions to small and medium businesses, the HP 2510 Switch Series consists of four Layer 2-managed switches that provide reliable 10/100 and 10/100/1000 connectivity. Building off of the popularity of the HP 2510-24 Switch, a 24-port 10/100 switch with two dual-personality ports, the 2510 switch series has expanded to include a higher-density HP 2510-48 Switch, with 48 10/100 ports and four Gigabit Ethernet uplinks. Additionally, the 2510-G switches add Gigabit Ethernet to the 2510 series, with the 2510G-24 and 2510G-48 switches, which are 24- and 48-port 10/100/1000 switches, each with four dual-personality ports, making them ideal for businesses that are ready to upgrade to increased network performance.
  • Quality of Service (QoS)
    IEEE 802.1p prioritization: delivers data to devices based on the priority and type of traffic.
  • Connectivity
    10/100 and 10/100/1000 connectivity: provides customers with the choice of selecting the network connectivity speed that best meets their needs, with a consistent user experience.Gigabit uplinks: E2510-24 and E2510-48 switches: the E2510-24 switch has two dual-personality ports for either 10/100/1000 or mini-GBIC connectivity; the E2510-48 switch has four Gigabit Ethernet ports, which can all be used concurrently with two 10/100/1000 ports and two open mini-GBIC slots. E2510G-24 and E2510G-48 switches: four dual-personality ports for 10/100/1000 or SFP ports for optional fiber connectivity such as Gigabit-SX, -LX, and -LH, or 100-FX.HP Auto-MDIX: automatically adjusts for straight-through or crossover cables on all 10/100 and 10/100/1000 copper ports.
  • Resiliency and high availability
    IEEE 802.1s Multiple Spanning Tree: provides high link availability in multiple VLAN environments by allowing multiple spanning trees; provides legacy support for IEEE 802.1d and IEEE 802.1w.IEEE 802.3ad Link Aggregation Control Protocol (LACP) and HP trunking: - E2510-24 switch supports up to two 10/100 trunks each with four links/ports plus one Gigabit Ethernet trunk. - E2510-48 switch supports up to 24 trunks with eight links/ports per trunk. - E2510-24G & E2510-48G switches support up to 24 trunks with eight links/ports per trunk.
  • Manageability
    IEEE 802.1AB Link Layer Discovery Protocol (LLDP): provides automated device discovery protocol for easy mapping by network management applications.RMON: provides advanced monitoring and reporting capabilities for statistics, history, alarms, and events.Full-featured console: provides complete control of the switch with a familiar command-line interface (CLI).Web interface: allows configuration of the switch from any Web browser on the network.Single IP Address Management: provides single IP address management for a virtual stack of up to 16 switches.
HPE 2510-24 Switch - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x combo Gigabit SFP
MAC Address Table Size
8K entries
Routing Protocol
IGMPv2, IGMPv3
Remote Management Protocol
SNMP 1, RMON, SNMP 3, SNMP 2c, HTTP
Flow control, Layer 2 switching, VLAN support, auto-uplink (auto MDI/MDI-X), manageable
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
44.3 cm x 23.6 cm x 4.4 cm
2.2 kg
English / United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
8K entries
Routing Protocol
IGMPv2, IGMPv3
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x MIPS: 264 MHz
RAM
64 MB SDRAM
Flash Memory
8 MB Flash
24 x 10Base-T/100Base-TX - RJ-45 , 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x console RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
30 Watt
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, cUL, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, UL 60950, CSA 22.2 No. 60950
44.3 cm
23.6 cm
4.4 cm
2.2 kg
Limited warranty - lifetime
45 °C
15 - 95%
551C HP Care Pack 4-hour 24x7 Same Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £175.79
