An X2 form-factor transceiver that supports the 10-Gigabit SR standard, providing 10-Gigabit connectivity up to 300 meters on multimode fiber.
- HPE - X2 transceiver module - 10GbE
- X2 transceiver module - SC/UPC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 300 m
- 3.6 cm x 8.8 cm x 1.1 cm
- 160 g
- Designed For
- HP Switch fl 1-Port 10-GbE X2 Interface Module, Switch fl 2-Port 10 GbE X2 Interface Module; HPE 10GbE Media Flex Module, 6410-6XG cl Switch, Switch 2900-24G, Switch 2900-48G, Switch yl 10-GbE 2P CX4 + 2P X2 Module; HPE Aruba 5406 zl, Switch 5400zl 4p 10-GbE X2 Module
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10GbE
- 10 Gbps
- 850 nm
- 300 m
- IEEE 802.3ae
- 1 x Ethernet 10GBase-SR - SC/UPC multi-mode x 2
- Compatible Slots
- 1 x X2
- 3.6 cm
- 8.8 cm
- 1.1 cm
- 160 g
- 0 °C
- 70 °C
- 0 - 95%
- Designed For
- HP Switch fl 1-Port 10-GbE X2 Interface Module, Switch fl 2-Port 10 GbE X2 Interface Module , HPE 10GbE Media Flex Module, 6410-6XG cl Switch, Switch 2900-24G, Switch 2900-48G, Switch yl 10-GbE 2P CX4 + 2P X2 Module , HPE Aruba 5406 zl, Switch 5400zl 4p 10-GbE X2 Module
