HPE HP ProLaint Moonshot 6SFP Uplink Module Kit
Quicklinx: 9NZZWS00 Mfr#: 704646-B21
Type: Modules
£566.71 ex VAT
£680.05 inc VAT
Do you want the freedom to simplify deployment with low-latency uplink connectivity? When you deploy your HP Moonshot 1500 Chassis, you have the ability to include up to two 6-port HP Moonshot–6SFP Uplink Modules. Paired with the HP Moonshot–45G Switch Module, you have a modular system that can dramatically simplify your data center. By disaggregating the uplink module from the internal switch, you have greater flexibility to deploy your choice of external interconnect, and to future-proof your investment. The Moonshot-6SFP Uplink Module features a low-power, low-latency design with six 10 GbE SFP+ ports. Each uplink module delivers 60 GbE of aggregate bandwidth to connect the HP Moonshot system to an external network.
  • Performance and Reliability
    HP Moonshot–6SFP Uplink Module provides high I/O performance with no oversubscription.Low-power, low-latency design.Redundant, dual modules within the HP Moonshot system provide traffic isolation and the ability to stack for resiliency.Modular design supports a range of current and future networking capabilities required for different solutions.
HPE Moonshot 6SFP Uplink Module Kit - expansion module - 6 ports
Expansion module
24.96 cm x 13.71 cm x 5.64 cm
1.39 kg
Ports Qty
6 ports
GigE, 10 GigE
Data Transfer Rate
10 Gbps
P/N: 700350-B21, 700350R-B21
Expansion module - 6 ports
Wired
Gigabit Ethernet, 10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
6 x network - SFP/SFP+
Compatible Slots
Expansion Slot
24.96 cm
13.71 cm
5.64 cm
1.39 kg
Type: Modules
Brand: HPE
Price Range Ex VAT: £500 - £750
