HPE X120 1G SFP LC LX Transceiver
Quicklinx: BGMQWS00 Mfr#: JD119B
£271.69 ex VAT
£326.02 inc VAT
HP X120 1G SFP LC LX Transceiver
  • Data transfer rate (max): 1,000 MBps
  • SFP transceiver type: LX
  • Fibre optic connector: LC
  • Fibre ports quantity: 1
  • Hot-plug support
HPE X120 - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
1GbE
HP 3100; HPE 10512, 12504, 1910, 3100, 3600, 5120, 5500, 5920AF, 7506; FlexFabric 1.92, 11908, 12902; FlexNetwork MSR3048; Networking Comware 2050 20, 2050 24, 2050 48, 2150 16, 2150 24, 2150 48, 2150 8p, 5150L 24
Plug-in module
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1 Gbps
1 x Ethernet 1000Base-LX - LC
Compatible Slots
1 x SFP (mini-GBIC)
HP 3100-8-PoE v2 EI Switch , HPE 10512 Switch Chassis, 12504 AC Switch Chassis, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 3100-24 V2 EI Switch, 3100-24-PoE v2 EI Switch, 3100-8 v2 SI Switch, 3600-24 v2 EI, 3600-24-PoE+ v2 EI, 3600-24-PoE+ v2 SI, 3600-24-SFP v2 EI, 3600-48-PoE+ v2 SI, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-PoE+-4SFP HI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 5920AF-24XG Switch, 7506 , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis, 12902E Switch Chassis , HPE FlexNetwork MSR3048 , HPE Networking Comware 2050 20p 10/100/1000BASE-T 4p Smart Rate 1/2.5GbE 4p SFP 1G/2.5G, 2050 24p 10/100/1000BT PoE+ 4p SFP 1G/2.5G 420W, 2050 48p 10/100/1000BASE-T 4p SFP 1G/2.5G, 2050 48p 10/100/1000BASE-T PoE+ 4p SFP 1G/2.5G 410W, 2150 16p 10M/100M/1G PoE+ 4p SFP+ 1G/10G 248W, 2150 24p 10M/100M/1G 4p SFP+ 1G/10G, 2150 48p 10M/100M/1G 4p SFP+ 1G/10G, 2150 48p 10M/100M/1G PoE+ 4p SFP+ 1G/10G 390W, 2150 48p 10M/100M/1G PoE+ 4p SFP+ 1G/10G 770W, 2150 8p 10M/100M/1G 2p SFP 1G 2p SFP+ 1G/10G, 2150 8p 10M/100M/1G PoE+ 2p SFP 1G 2p SFP+ 1G/10G 125W, 5150L 24p 10M/100M/1G PoE+ 4p SFP 1G Combo 4p SFP+ 1G/10G 405W
Brand: HPE
