HP Mobile Broadband Modules are integrated WWAN modules for select HP notebooks that allows connection to, and permit roaming on, wireless networks in many countries worldwide. (Separately purchased carrier service required.) With an HP Mobile Broadband-enabled notebook and wireless carrier service, you can check e-mail, browse the Internet, and connect to corporate networks from anywhere within the coverage area - whether you are stationary or on the go. Enjoy the freedom of connecting in more places, the speed of broadband, the coverage of 3G networks, and the security, reliability, and ease of use of HP business notebooks today!
- HP un2430 - wireless cellular modem - 3G
- Wireless cellular modem - PCIe Mini Card
- Form Factor
- Internal
- Max Transfer Rate
- 7.2 Mbps
- Mobile Communication Protocol
- GSM, GPRS, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, WCDMA, HSPA, CDMA 2000 1X EV-DO Rev. 0
- Microsoft Certification
- Compatible with Windows 7
- 3 cm x 5.1 cm x 0.5 cm
- 12 g
- Designed For
- EliteBook 2560p, 2760p, 8460p Notebook, 8460w Mobile Workstation, 8560p Notebook, 8760w Mobile Workstation; EliteBook Folio 9470m; ProBook 5330m
- Form Factor
- Internal
- Built-in Devices
- GPS
Modem
- Bus
- PCIe Mini Card
- Connectivity Technology
- Wireless
- Max Transfer Rate
- 7.2 Mbps
- Antenna Qty
- 1
- Assisted GPS
- Compatible Slots
- 1 x PCI Express Mini Card
- Software Included
- HP Connection Manager
- 3 cm
- 5.1 cm
- 0.5 cm
- 12 g
- -30 °C
- 60 °C
- Designed For
- HP EliteBook 2560p, 2760p, 8460p Notebook, 8460w Mobile Workstation, 8560p Notebook, 8760w Mobile Workstation , HP EliteBook Folio 9470m , HP ProBook 5330m
