HPE HP ProLiant Moonshot-4QSFP+ Uplink Module Kit
Quicklinx: 9P00WS00 Mfr#: 704652-B21
Type: Modules
£3,512.96 ex VAT
£4,215.55 inc VAT
Do you want the freedom to simplify deployment with low-latency uplink connectivity? When you deploy your HP Moonshot 1500 Chassis, you have the ability to include up to two 4-port HP Moonshot-4QSFP+ Uplink Modules. Paired with the HP Moonshot-180G Switch Module, you have a modular system that can dramatically simplify your data center. By disaggregating the uplink module from the internal switch, you have greater flexibility to deploy your choice of external interconnect and to future-proof your investment. The Moonshot-4QSFP+ Uplink Module features a low-power, low-latency design with four 40 GbE QSFP+ ports. Each uplink module delivers 160 GbE of aggregate bandwidth to connect the HP Moonshot System to an external network.
  • Performance and Reliability
    HP Moonshot-4QSFP+ Uplink Module provides high I/O performance with reduced oversubscription.Low-power, low-latency design.Redundant, dual modules within the Moonshot system provide traffic isolation and the ability to stack for resiliency.Modular design supports a range of current and future networking capabilities required for different solutions.
HPE Moonshot 4QSFP+ Uplink Module Kit - expansion module - 40 Gigabit QSFP+ x 4
Expansion module
Ports
24.96 cm x 13.71 cm x 5.64 cm
963 g
10 GigE, 40 Gigabit LAN
Data Transfer Rate
40 Gbps
Moonshot 1500, 180G Switch Module
Expansion module
Ports
Wired
10 Gigabit Ethernet, 40 Gigabit Ethernet
Data Transfer Rate
40 Gbps
Status Indicators
Port status, module locator, link/activity
4 - QSFP+ , 1 x management - RJ-45
UL 60950-1, EN 60950-1, RoHS, EMC Class A, CAN/CSA-C22.2 No. 60950-1
24.96 cm
13.71 cm
5.64 cm
963 g
10 °C
35 °C
10 - 90% (non-condensing)
HPE Moonshot 1500, 180G Switch Module
Type: Modules
Brand: HPE
Price Range Ex VAT: £1500+
