HPE HP ProLiant GBE2C Ethernet Kit
Quicklinx: 50J1WS00 Mfr#: 438030-B21
The HP GbE2c Layer 2/3 Ethernet Blade Switch provides a full set of Layer 2 switching and Layer 3 routing features, sixteen internal downlinks, five uplinks and two internal cross-connects in a single low cost blade switch. Four of the five uplinks can be either copper or fiber using optional SFP fiber modules. This switch dramatically reduces cabling, power and cooling requirements compared to external stand-alone switches, allowing you to realize the full benefits of the HP c-Class BladeSystem. The HP GbE2c Layer 2/3 Ethernet Blade Switch builds on the heritage of the GbE2 switch family by delivering on-going enhancements such as a new "industry standard" CLI, Layer 3 routing, high availability features and SFP Fiber uplink ports. Along with simplified management, wire-speed performance, redundant path capabilities and HP's world class service and support, the HP GbE2c Layer2/3 Ethernet Blade Switch remains the price/performance leader of all blade switches.
  • High Performance
    The HP GbE2c Layer 2/3 Ethernet Blade Switch provides a full set of Layer 2/3 features along with seamless integration into any copper or fiber network makes this switch a perfect fit for deployment in the HP BladeSystem enclosure.HP GbE2c Layer 2/3 Ethernet Blade Switch provides wire speed switching for incoming or outgoing traffic, providing up to 20Gb of switching capacity or 7.8 Million packets per second switching performance.HP GbE2c Layer 2/3 Ethernet Blade Switch provides all advanced Layer 2 features including extensive support for VLANs, Spanning Tree, Rapid Spanning, Multiple Spanning Tree and Uplink Failure Detection. IGMP Snooping improves overall bandwidth, conserves CPU server cycles avoiding server upgrades.Layer 3 routing gives administrators more power, flexibility and security. Network traffic is more efficient; traffic between servers stays in the enclosure. Security features add protection for switch configuration data and packet filtering secures and segments sensitive traffic or network access.VLANs configured to provide data segregation, improve bandwidth, performance and limit traffic to designated domains. The L2/3 Switch provides secured access through SSH v2, protects against IP and DNS spoofing and helps users meet security requirements through support for HTTPS, RADIUS and TACACS.
HPE GbE2c Layer2/3 Ethernet Blade Switch for c-Class BladeSystem - switch - 16 ports - Managed - plug-in module
Switch - 16 ports - Managed
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 + 4 x SFP + 5 x 10/100/1000
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS
BOOTP support, IGMP snooping, store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ac, IEEE 802.1s, IEEE 802.3d
36.8 cm x 29 cm x 6 cm
2 kg
1-year warranty
BLc3000 Enclosure; BLc7000 Enclosure; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; ProLiant BL460c, BL465c, BL480c, BL685c
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Compatible Slots
1 x Expansion Slot
Ports
8K entries
Authentication Method
RADIUS, TACACS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB SDRAM
Flash Memory
16 MB Flash
5 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC)
FCC Class A certified, VCCI Class A ITE, AS/NZ 3548 Class A, ICES-003 Class A
36.8 cm
29 cm
6 cm
2 kg
Limited warranty - parts and labour - 1 year - on-site
5 - 95%
HPE BLc3000 Enclosure , HPE BLc7000 Enclosure , HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses, w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE ProLiant BL460c, BL465c, BL480c, BL685c
