This MIMO antenna is specifically designed to meet the needs of today's most demanding wireless LAN deployments. E-series MIMO external antenna supports the dual band access point deployments, providing maximum flexibility to help optimize coverage and radio signal predictability.
High-gain omnidirectional or directional antennas
It provides specific RF pattern characteristics to increase wireless coverage and signal gain or overcome physical/RF interference. -
Certified external antennas
It's specifically designed and certified for use with wireless access points.
- HPE Indoor-Outdoor Point-to-Point Dual Band 10/13dBi MIMO 3 Element Antenna - antenna
- Product Type
- Antenna
- Aerial Placing / Mounting
- Outdoor, indoor
- Gain
- 10 dBi, 13 dBi
- Directivity
- Directional
- Designed For
- HPE MSM466 Dual Radio 802.11n Access Point, MSM466 Dual Radio 802.11n AP, MSM466-R Dual Radio Outdoor 802.11n Access Point
- Product Type
- Antenna
Aerial
- Outdoor, indoor
- Gain
- 10 dBi, 13 dBi
- Directivity
- Directional
- Designed For
- HPE MSM466 Dual Radio 802.11n Access Point (AM), MSM466 Dual Radio 802.11n Access Point (IL), MSM466 Dual Radio 802.11n AP (AJ), MSM466 Dual Radio 802.11n AP (WW), MSM466-R Dual Radio Outdoor 802.11n Access Point (AM), MSM466-R Dual Radio Outdoor 802.11n Access Point (IL), MSM466-R Dual Radio Outdoor 802.11n Access Point (WW)
