The HP vl 20p Gig-T+ 4P SFP module switch provides 20 ports of 10/100/100-T and 4 ports of SFT for use in the Switch 4200vl series.
- HPE vl 20p Gig-T+ 4P SFP module switch - expansion module - Gigabit Ethernet x 20
- Expansion module
- Form Factor
- Plug-in module
- Ports
- 20.3 cm x 22.8 cm x 4.5 cm
- 0.69 kg
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Auxiliary Ports
- 4 x SFP (mini-GBIC)
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Designed For
- HPE 4208-96 vl Switch
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Auxiliary Ports
- 1 Gbps
- Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
- Expansion Slots
- 4 (total) / 4 (free) x SFP
- 20 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x Expansion Slot
- 20.3 cm
- 22.8 cm
- 4.5 cm
- 0.69 kg
- Designed For
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.53 |
