HP 8-port 10GBase-T v2 zl Module is for medum distance (upto 100m) 10G connectivity without the need for transceivers, using existing cabling infrastructure.
- Application/Usage Data Networking
- Interfaces/Ports 8 x 10Base-T LAN
- Interfaces/Ports Details 8 x RJ-45 10Base-T Network LAN
Dimensions (W x D x H)
10.3 x 8.13 x 1.75 in. (26.16 x 20.65 x 4.45 cm)
- HPE - expansion module - 10Gb Ethernet x 8
- Expansion module
- Form Factor
- Plug-in module
- Ports
- 10Gb Ethernet x 8
- Cabling Type
- Ethernet 10GBase-T
- Data Link Protocol
- 10GbE
- Data Transfer Rate
- 10 Gbps
- Designed For
- HPE 8206, 8206-44G-PoE+/2XG-SFP+ v2, 8212, 8212-92G-PoE+/2XG-SFP+ v2; HPE Aruba 5406, 5406-44G-PoE+/4SFP, 5406-44G-PoE+-2XG v2, 5406-48G, 5412, 5412-92G-PoE+/4SFP, 5412-92G-PoE+-2XG v2, 5412-92G-PoE+-4G v2, 5412-96G
- Expansion module
- Form Factor
- Plug-in module
- Ports
- 10Gb Ethernet x 8
- Connectivity Technology
- Wired
- Cabling Type
- 10 Gigabit Ethernet
- 10 Gbps
- 8 x 10GBase-T - RJ-45
- Compatible Slots
- 1 x Expansion Slot
- Designed For
- HPE 8206 zl Switch, 8206-44G-PoE+/2XG-SFP+ v2 zl Switch, 8212 zl Switch, 8212-92G-PoE+/2XG-SFP+ v2 zl Switch , HPE Aruba 5406 zl, 5406-44G-PoE+/4SFP Rack Shippable zl Switch, 5406-44G-PoE+/4SFP zl, 5406-44G-PoE+-2XG v2 zl, 5406-48G Rack Shippable zl, 5406-48G zl, 5412 zl, 5412-92G-PoE+/4SFP Rack Shippable zl, 5412-92G-PoE+/4SFP zl, 5412-92G-PoE+-2XG v2 zl, 5412-92G-PoE+-4G v2 zl, 5412-96G zl
