HP R/T 3KVA UPS 2U DTC HV INTL KIT
Quicklinx: 724DWS00 Mfr#: AF454A
HP R/T3000 Uninterruptible Power System (UPS) packs up to 3000 watts into a space saving 2U design. The Digital Signal Processor (DSP) provides clean, reliable power protection in an energy efficient transformerless design while reducing generated heat.
  • 2U power packed design
    Rated near unity at 3300 VA / 3000 W, the HP UPS R/T3000 packs more power in space-conserving rack-mount design, allowing you to support more critical equipment in your rack.
  • Increase system uptime with extended runtime modules
    The Extended Runtime Modules are external battery modules that occupy 2U of rack space each. The HP UPS R/T3000 supports up to two Extended Runtime Modules (ERM), in either rack mount or tower configuration, which extend your overall battery runtime.
  • Lower cost of ownership with advanced technology
    The HP UPS R/T3000 utilizes a powerful technology that continually conditions and regulates power without using the battery, thereby increasing the life of the battery. The output voltage is automatically regulated, based on the connected load and the input voltage.
  • Investment protection with HP Enhanced Battery Management
    HP UPS R/T3000 incorporates Enhanced Battery Management: an advanced technology that doubles battery service life, optimizes battery recharge time, and provides advance notice of pending battery failure. With Enhanced Battery Management, you have a lower total cost of ownership and get the maximum in the industry protection for your critical equipment.
  • Enhanced front panel display
    LED and switch membrane integrated into the front panel with power controls and status and load indicators for easy visibility.
HPE UPS R/T3000 High voltage - UPS - 3 kW - 3300 VA
UPS - external
Rack Size
2U
37 kg
Input Voltage
AC 220/230/240 V
Output Voltage
± 5%
Power Capacity
3 kW / 3300 VA
Input Connectors
1 x power NEMA L6-20
Output connectors
6 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid expandable
Batteries Qty
1
Run Time (Up To)
4 min at full load
44.5 cm x 63.5 cm x 8.9 cm
HP 10642U; ProLiant DL120 G6, DL360 G5, DL360 G7, DL365 G5, DL370 G6, DL380 G7, DL385 G7, DL580 G5, DL580 G7, DL585 G5, DL585 G6, DL585 G7, DL785 G5, DL980 G7, ML350 G5, ML370 G5, ML370 G6; Rack 10614, 10622, 10622 G2, 10636, 10636 G2, 10642, 10642 G2, 10647, 10647 G2, 10842, 10842 G2, 5642
UPS - external
Height (Rack Units)
2U
Input Voltage
AC 220/230/240 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
± 5%
Power Capacity
3 kW / 3300 VA
Output Waveform
Sinewave
Surge Suppression
Expandable
Quantity
1
Lead Acid
Run Time (Up To)
4 min at full load
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type A
Serial cable - external , USB cable - external
Rack Mounting Kit
Included
Equipment Protection Value
250000 US Dollars
Remote Power Off
UL, GOST, cUL, GS, UL 1778, IEC 62040-1-1, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07
Software Included
Drivers & Utilities
10 °C
20 - 80%
Sound Emission
45 dB
44.5 cm
63.5 cm
8.9 cm
37 kg
Shipping Width
59.6 cm
Shipping Depth
92.1 cm
Shipping Height
28.6 cm
Shipping Weight
40.4 kg
HP 10642U Special Rack , HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 High Efficiency, DL360 G5 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL365 G5, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL580 G5, DL580 G5 Base, DL580 G5 High Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G5, DL585 G5 High Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G5, DL980 G7, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 High Performance, ML370 G5 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry , HPE Rack 10614 Shock Pallet, 10622, 10622 G2 Pallet, 10622 G2 Shock Pallet, 10636, 10636 G2, 10636 G2 Crated, 10636 G2 Pallet, 10636 G2 Shock Pallet, 10636 Pallet, 10636 Shock Pallet, 10642, 10642 G2, 10642 G2 Crated, 10642 G2 Pallet, 10642 G2 Shock Pallet, 10642 Shock Pallet, 10647, 10647 G2 Pallet, 10647 G2 Shock Pallet, 10842, 10842 G2 Pallet, 10842 G2 Shock Pallet, 10842 G2 Wide Rack Cabinet Pallet, 10842 G2 Wide Rack Cabinet Shock Pallet, 5642
