Hauppauge mySmarthome is an easy, versatile solution to turn your home into a smart home. mySmarthome is reliable and secure, and can save energy by controlling lights and heat in your home. And with the cloud based alert system, you'll know when something happens in your home.
- Hauppauge mySmarthome Control Starter Kit - home automation kit - Z-Wave
- Product Type
- Home automation kit
- Sensor Type
- Temperature, ambient light, door and window, motion
- Package Content
- Multipurpose sensor, central controller, smart plug
- Connectivity
- Wireless - Z-Wave
- Supported Host Device OS
- iOS, Android
- Product Type
- Sensor Type
- Package Content
- Components
- Multipurpose sensor , Central controller , 2 x smart plug
- Connectivity Technology
- Wireless - Z-Wave
- iOS, Android
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Included
- Communications Type
- Product-to-product
- Communications Technology
- Z Wave
