Fujitsu ScanSnap N1800
Quicklinx: 7CQYWS00 Mfr#: PA03609-B001
The easy-to-use N1800 is a network scanner offering cloud linking functions as well as enabling users to email, save and print scanned documents through a network. With an intuitive touchscreen complete with GUI keyboard, the N1800 is efficient, secure and intelligent, thereby minimizing operator involvement before, during and after the scanning process.
The N1800 network imaging scanner is designed to speedily digitize documents and facilitate the paperwork of everyone in the office whether directly into a company's business processes, local network or into the cloud. Directly link the N1800 to a network and digitize documents into processed data for e-mails, faxes, network storage and much more all with remarkable ease in a compact footprint and with intelligent functions to minimize operator involvement.
Whether your documents are monochrome or color, large or small, or a combination of those, just press the Scan button on the N1800 touch panel to convert them into digital data. With the scanner connected to a network, you can directly save and share the digital data through a network resource, including a cloud service such as Google Docs or Salesforce CRM.
Advanced automated functions such as paper size detection, color detection, blank page removal, auto deskew and auto orientation ensure the N1800 digitizes your documents with remarkable precision and efficiency producing flawless scans quickly and without barely lifting a finger.
The N1800 delivers scanning speeds of up to 20 ppm / 40 ipm (color, A4 size at 200 and 300 dpi). Very accurate ultrasonic sensors detect when overlapping pages (multifeed) enter the imaging device. The N1800 features a large, vibrant touch panel, which utilizes 'One Push' interface, so anyone can operate the imaging device with ease.
The N1800 comes armed with advanced security features to ensure safe and secure operation among multiple users, it satisfies the digitizing needs of small networks that use a file server and e-mail server. It's also right at home with more complex LDAP/LDAPS authentication-based networks, integrated with Microsoft Exchange Server, SharePoint and other application hubs.
Collectively monitor and manage scanner usage, setting and much more for multiple N1800 units, through the Scanner Central Admin Server function.
Fujitsu ScanSnap N1800 - document scanner - desktop - LAN
Document scanner - desktop
Interface Type
LAN
Scanning Sensor Type
Dual CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
216 x 3024 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
20 ppm (mono) / 20 ppm (colour)
Max Document Size
216 mm x 3024 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
30 cm x 22.6 cm x 17.2 cm
6 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
LAN
216 x 3024 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CCD
Bulb / Light Source Type
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
20 ppm
Scanner Speed Details
20 ppm - black & white - A4 - 200 dpi , 40 ipm - duplex - black & white - A4 - 300 dpi , 20 ppm - colour - A4 - 200 dpi , 40 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
8.4" touch screen TFT display, Ultrasonic multifeed sensor, automatic page size detection
Media Handling
Max Document Size
216 mm x 3024 mm
Automatic
50 sheets
Supported Protocols
DHCP, FTP, HTTP, NTP, SMTP, TCP/IP, SMB, LDAP
LAN
1 x network cable
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
50 Watt (0.5 Watt)
30 cm
22.6 cm
17.2 cm
6 kg
5 °C
35 °C
20 - 80%
