Freecom RDX USB  Ext Bundle+160GB+S/W
Quicklinx: 776RWS00 Mfr#: 34919
Freecom's RDX Removable Hard Drive Storage System makes your data backup easier, faster, more reliable and more secure. Its enterprise-class features provide the data protection of large IT data centers, so it can support your company as it grows, and all at an affordable price. The Freecom RDX Removable Storage System is designed to protect your business' valuable assets. It uses a rugged, removable disk cartridge and docking station that backs up just like a tape drive. The Freecom RDX Storage System is able to back up more than 125GB of data per hour and allows you to access files instantly. And you'll never run out of storage space, simply add more removable cartridges as your data needs expand. Its enterprise-class features provide the data protection of large IT data centers, so it can support your company as it grows, and all at an affordable price.
The Freecom RDX Storage System is designed to reliably protect your business' valuable assets. It uses a rugged, reliable removable disk cartridge and docking station that backs up just like a tape drive.
Freecom's RDX Removable Hard Drive Storage System combines the robust RDX technology with award-winning Yosemite software to make protecting data even easier. The software installs in minutes and delivers fast backups, accurate restores and file disaster recovery with minimal manual effort or expertise. Plus, it features the government certified 256-bit AES encryption ensuring that sensitive data remains secure.
Freecom RDX Removable Hard Drive Storage System RDX drive - USB 2.0 - external - with 160 GB Cartridge
RDX drive - external
USB 2.0
11 cm x 17.8 cm x 5.2 cm
635 g
Storage Removable
RDX cartridge
Media Type
RDX cartridge
Data Transfer Rate
25 MBps (external)
Bundled with
160 GB Cartridge
USB 2.0
11 cm
17.8 cm
5.2 cm
635 g
Bundled with
160 GB Cartridge
Storage Removable
RDX cartridge
Media Type
RDX cartridge
Data Transfer Rate
25 MBps (external)
1 x USB 2.0
FCC
