Freecom DAT-160i 80-160GB internal SCSI
Quicklinx: 4S7ZWS00 Mfr#: 29770
The internal Freecom DAT-160i SCSI Tape Drive is a reliable, reasonably priced backup solution for small to medium-sized servers and high-end workstations. The drive is able to store 160 GB (compressed) in 3.5 hours and is thus the ideal solution for all high-volume applications. This DDS-6 compatible tape drive is also backwards compatible (read and write) with generation DDS-4 and DDS-5 drives.
Freecom TapeWare DAT 160i - tape drive - DAT - SCSI
Tape drive
Recording Standard
DAT-160
Enclosure Type
Internal
Interface Type
SCSI LVD
14.5 cm x 17.7 cm x 4 cm
1.2 kg
Storage Removable
DAT - 5.25" x 1/2H
Storage Removable Capacity
80 GB (native) / 160 GB (compressed)
Supported Tape Cartridges (Read and Write)
DDS-4, DAT-72, DAT-160
Data Transfer Rate (native)
6.9 MBps (25 GBph)
Data Transfer Rate (compressed)
13.8 MBps (49.7 GBph)
3-year warranty
Tape drive - DAT
Recording Standard
DAT-160
Enclosure Type
Internal
Interface Type
SCSI LVD
Enclosure Colour
14.5 cm
17.7 cm
4 cm
1.2 kg
Storage Removable
DAT - 5.25" x 1/2H
Recording Standard
DDS-4, DAT 72, DDS-5, DAT 160, DDS-6
6.9 MBps (25 GBph)
Average Seek / Access Time
50 sec
Buffer Size
16 MB
1 x Ultra160 SCSI LVD
Compatible Bay
1 x front accessible - 5.25" x 1/2H
Media Included Qty
1
Cleaning cartridge
1 x SCSI cable
TUV, VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, CISPR 22, CSA 22.2 No. 60950, FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - 3 years
5 °C
20 - 80%
