The internal Freecom DAT-160i SCSI Tape Drive is a reliable, reasonably priced backup solution for small to medium-sized servers and high-end workstations. The drive is the ideal solution for all high-volume applications.
- Freecom TapeWare DAT 160i - tape drive - DAT - USB 2.0
- Tape drive
- Recording Standard
- DAT-160
- Enclosure Type
- Internal
- Interface Type
- USB 2.0
- 14.5 cm x 18.3 cm x 4 cm
- 1.2 kg
- Black
- Storage Removable
- DAT - 5.25" x 1/2H
- Storage Removable Capacity
- 80 GB (native) / 160 GB (compressed)
- Supported Tape Cartridges (Read and Write)
- DDS-4, DAT-72, DAT-160
- Data Transfer Rate (native)
- 6.9 MBps (25 GBph)
- Data Transfer Rate (compressed)
- 13.8 MBps (49.7 GBph)
- 3-year warranty
- Tape drive - DAT
- DAT-160
- Enclosure Type
- Internal
- Interface Type
- USB 2.0
- Enclosure Colour
- Black
- 14.5 cm
- 18.3 cm
- 4 cm
- 1.2 kg
Storage Removable
- Capacity
- DDS-4, DAT 72, DDS-5, DAT 160, DDS-6
- Average Seek / Access Time
- 50 sec
- Buffer Size
- 16 MB
- 1 x USB 2.0
- Compatible Bay
- 1 x front accessible - 5.25" x 1/2H
- Media Included Qty
- 1
- Included Accessories
- Cleaning cartridge
- TUV, VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, CISPR 22, CSA 22.2 No. 60950, FCC, RoHS
- Package Type
- Bulk
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80%
