The FortiSwitch-80-POE provides full 15.4 watts/port of Power over Ethernet (POE) in a cost-effective form factor for the distributed enterprise or small office. This eight-port GbE switch provides 62 watts of POE power to four devices, the highest in the industry. You can connect wireless access points, IP phones, and IP cameras to the POE ports. The FortiSwitch-80-POE eliminates the need for additional POE injectors, simplifying your small office network while improving performance. The remaining four GbE ports can accommodate uplink ports as well as additional devices such as printers, and back office equipment.
- Fortinet FortiSwitch 80-PoE - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 4 x 10/100/1000 (PoE) + 4 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- Performance
- Throughput: 2 Gbps
- MAC Address Table Size
- 2K entries
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, full duplex mode
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3af, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- 12 cm x 19 cm x 3.8 cm
- 0.75 kg
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- 2K entries
- Status Indicators
- Port transmission speed, power, link/activity
- 4 x 1000Base-TX RJ-45 , 4 x 1000Base-TX RJ-45 PoE
- Power Device
- External power adapter
- Voltage Required
- 68.2 Watt
- 12 cm
- 19 cm
- 3.8 cm
- 0.75 kg
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- 0 °C
- Max Storage Temperature
- 50 °C
