Fortinet FortiSwitch 548D Switch
Quicklinx: CJR6WS00 Mfr#: FS-548D-FPOE
FortiSwitch Secure Access switches deliver outstanding security, performance and manageability for threat conscious small to mid-sized businesses, distributed enterprises and branch offices. Tightly integrated into the FortiGate Network Security Platform, the FortiSwitch secure access switches can be managed directly from the familiar FortiGate interface. This single pane of glass management provides complete visibility and control of all users and devices on the network, regardless of how they connect.
When a device connects to a secure access switch Ethernet port, it is first identified, and then the user is authenticated. Once authenticated, access to the network is granted based on pre-defined security policy from the FortiGate, ensuring secure network access across the enterprise, without impacting the user experience.
  • Single management framework
    Reduces complexity and decreases management cost with network security functions managed through a singleconsole.
  • Single policy provisioning
    The same security policy can apply to a user or device regardless of how or where they connect to the network. Enables access to certain network ports based on the role of a user within the organization, such as in shared conference rooms or engineering facilities.
  • Centralized authentication
    All users are authenticated against the same user database, regardless of whether they connect to the wired or wireless network, including temporary guest users.
  • Role-based ports
Fortinet FortiSwitch 548D - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+ + 2 x 40 Gigabit QSFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
750 W
Performance
Switching capacity: 336 Gbps , Latency: 2 µs
Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 26
MAC Address Table Size
96K entries
Jumbo Frame Support
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH-2, CLI
Power over Ethernet (PoE), IGMP snooping, Syslog support, traffic shaping, port mirroring, DiffServ support, Broadcast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, PoE+, Link Aggregation Control Protocol (LACP), DHCP client, Management Information Base (MIB), tagged VLAN, Generic VLAN Registration Protocol (GVRP)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3at
44 cm x 31 cm x 4.4 cm
7.14 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
750 W
Performance
96K entries
Jumbo Frame Support
Routing Protocol
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
48 x 1000Base-T RJ-45 PoE+ , 4 x 10Gbit LAN SFP+ , 2 x 40Gbit LAN QSFP+ , 1 x 1000Base-T RJ-45 management , 1 x console RJ-45
Internal power supply
961 Watt
44 cm
31 cm
4.4 cm
7.14 kg
Limited warranty - lifetime
45 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
