FortiSwitch Secure Access switches deliver outstanding security, performance and manageability for threat conscious small to mid-sized businesses, distributed enterprises and branch offices. Tightly integrated into the FortiGate Network Security Platform, the FortiSwitch Secure Access switches can be managed directly from the familiar FortiGate interface. This single pane of glass management provides complete visibility and control of all users and devices on the network, regardless of how they connect.
When a device connects to a Secure Access Switch Ethernet port, it is first identified, and then the user is authenticated. Once authenticated, access to the network is granted based on pre-defined security policy from the FortiGate, ensuring secure network access across the enterprise, without impacting the user experience.
- Fortinet FortiSwitch 448D - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Ports
- 48 x 10/100/1000 + 4 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 740 W
- Performance
- Switching capacity: 176 Gbps , Latency: 1 µs
- Capacity
- Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 13
- MAC Address Table Size
- 16K entries
- Remote Management Protocol
- CLI
- Flow control, power over Ethernet (PoE), port mirroring, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Jumbo Frames support, LLDP support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), tagged VLAN
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 31 cm x 4.4 cm
- 4.15 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Ports
- PoE+
- PoE Budget
- 740 W
- Performance
- Capacity
- 16K entries
- CLI
- RAM
- 1 GB
- Flash Memory
- 128 MB
- Status Indicators
- Power, PoE, link/activity
- 48 x 1000Base-TX RJ-45 PoE+ , 4 x 10Gbit LAN SFP+ , 1 x 1000Base-T RJ-45 management , 1 x console RJ-45
- Power Device
- Internal power supply
- Installed Qty
- 2
- Voltage Required
- 397 Watt
- MTBF
- 10 years
- UL, VCCI, BSMI, CB, FCC, RoHS2, RCM
- 44 cm
- 31 cm
- 4.4 cm
- 4.15 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
