The FortiSwitch-108D-POE is a Desktop Form-factor Switch, equipped with 8 dedicated RJ45 Gigabit Ethernet ports and 2 RJ45/SFP combo ports. Perfect for extending the port count on desktop FortiGate connected UTM models, or to provide Secure Network Access to Wired LAN clients, the FortiSwitch-108D-POE is designed with the needs of the distributed enterprise or SMB in mind. The built-in Power over Ethernet (POE) ports enables the simple and rapid installation of POE capable devices, such as wireless access points and IP phones, reducing your overall network TCO.
The FortiSwitch-108D-POE supports logical network segmentation and visibility, enabling the convergence of voice, data and wireless traffic onto a single network platform, while still meeting compliance requirements for data separation.
- Fortinet FortiSwitch 108D-POE - switch - 8 ports - Managed
- Switch - 8 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 75 W
- Performance
- Switching throughput: 20 Gbps
- Capacity
- Virtual interfaces (VLANs): 512
- Jumbo Frame Support
- Routing Protocol
- IGMPv2, IGMP
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH-2, CLI
- Power over Ethernet (PoE), IGMP snooping, Syslog support, traffic shaping, port mirroring, DiffServ support, Broadcast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, Link Aggregation Control Protocol (LACP), DHCP client, Management Information Base (MIB), tagged VLAN, Generic VLAN Registration Protocol (GVRP)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 20 cm x 33 cm x 4.4 cm
- 1.9 kg
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 75 W
- Performance
- Capacity
- Routing Protocol
- IGMPv2, IGMP
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
- Status Indicators
- Port transmission speed, power, status, PoE
- 8 x 1000Base-TX RJ-45 , 2 x SFP
- Power Device
- Internal power supply
- Voltage Required
- 95.1 Watt
- RoHS
- 20 cm
- 33 cm
- 4.4 cm
- 1.9 kg
- 0 °C
- 45 °C
- 5 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
