Gaming graphics
The EH-TW5200 delivers a 15,000:1 contrast ratio and is enhanced by Epson’s 3LCD technology for high definition 2D and 3D images on a big screen. You no longer have to sit in the dark to see what you're doing during the day, thanks to an equally high White and Colour Light Output of 2,000 lumens.
Big screen entertainment
The screen size ranges from 30 inches up to 300 inches, and can be adjusted to project a straight image effortlessly with keystone correction. This means you don't need large open areas or to clear a lot of space to enjoy.
No lag time
Switching to 'fast mode' means that fast-paced football games or online multiplayer video games are projected smoothly and accurately. With no lag time, the action is projected without delay – important for tournaments or matches that need split-second reaction times.
MHL support
The EH-TW5200 offers a wide selection of connectivity options, including one HDMI - MHL port. This means that not only can you play Full HD content, but also videos, music and photos from your smartphone and tablet.
3D home cinema
You can easily switch to 3D content that is noticeably brighter than many Full HD 3D home cinema projectors. Paired with lightweight, rechargeable Radio Frequency (RF) active shutter 3D glasses(sold separately) you can easily enjoy your content without interference.
- Epson EH-TW5200 - 3LCD projector - portable - 3D
- 3LCD projector - High Definition 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness (White)
- 2000 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Bulb type
- 200 Watt
- Bulb life cycle
- Up to 5000 hour(s) / up to 6000 hour(s) (economic mode)
- Video Input
- Composite video
- Video Modes
- 1080p
- Speakers
- Speaker(s) - integrated
- 287 Watt
- 29.7 cm x 24.7 cm x 10.5 cm
- 2.8 kg
- 2 years warranty
- 3LCD projector - HD 1080p
- 3D Capable
Projector
- 2000 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 86 cm - 833 cm
- Projection Distance
- 0.9 m - 10.8 m
- Throw Ratio
- 1.22 - 1.47:1
- Resolution
- 16:9
- Bulb type
- 200 Watt
- Bulb life cycle
- EPSON Super White, Auto Vertical Keystone, EPSON 3LCD technology, 16:9 aspect ratio support, Game mode, Dynamic Mode, Theater Mode, 480hz 3D drive, MHL compliance
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.58-1.72
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Composite video
- Video Interfaces
- HDMI, composite video
- Video Modes
- 1080p
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 2 Watt
- Speakers
- 2 x right / left channel
- 1 x composite video input - RCA , 2 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A
- Included Accessories
- Wireless remote control
- Security Features
- 287 Watt
- Power Consumption Stand by
- 0.31 Watt
- 29.7 cm
- 24.7 cm
- 10.5 cm
- 2.8 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 2000 hours
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 0.5m Select High Speed HDMI with Ethernet | In Stock | £5.79 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £15.65 |
C2G 10m Select High Speed HDMI with Ethernet | In Stock | £30.41 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £41.19 |
C2G Pro HDMI to VGA Converter | In Stock | £46.73 |
