Bigger is better
Feel immersed in your favourite movies and games with this Full HD projector, that's capable of creating an impressive 300 inch display. Bringing the screen to life, 3LCD technology achieves a display that is up to three times brighter than competitor products . Its 15,000:1 contrast ratio also produces clearly defined shadows and deep blacks.
Simple set up
We don't think a home projector should be any more complicated to use than a TV. That's why this projector is hassle-free and quick to set up with features such as keystone correction to help quickly position the image. Accessing your entertainment is easy too with two HDMI inputs (including one MHL) for connecting DVD players, games consoles and more. By using the optional ELPAP10 adapter, it can also offer Wi-Fi connectivity, allowing you to share content from a smart device using the iProjection app.
Long-lasting solution
Looking for a long-term, hassle-free and affordable solution for watching your favourite movies? With this model's long-lasting lamp light source, you'll be able to watch a film every day for 15 years .
High-quality, bright images
Even in bright rooms, this powerful yet affordable Full HD projector delivers exceptionally bright yet colourful images with clear details. It's all thanks to 3LCD technology, which produces an equally high White and Colour Light Output of 3,400 lumens.
Bigger is better
Feel immersed in your favorite movies and games with this Full HD projector, that's capable of creating an impressive 300 inch display. Bringing the screen to life, 3LCD technology achieves a display that is up to three times brighter than competitor products. Its 15,000:1 contrast ratio also produces clearly defined shadows and deep blacks. -
Simple set up
We don't think a home projector should be any more complicated to use than a TV. That's why this projector is hassle-free and quick to set up with features such as keystone correction to help quickly position the image. Accessing your entertainment is easy too with two HDMI inputs (including one MHL) for connecting DVD players, games consoles and more. By using the optional ELPAP10 adapter, it can also offer Wi-Fi connectivity, allowing you to share content from a smart device using the iProjection app. -
Looking for a long-term, hassle-free and affordable solution for watching your favorite movies? With this model's long-lasting lamp light source, you'll be able to watch a film every day for 15 years. -
Even in bright rooms, this powerful yet affordable Full HD projector delivers exceptionally bright yet colorful images with clear details. It's all thanks to 3LCD technology, which produces an equally high White and Color Light Output of 3,400 lumens.
- Epson EB-U05 - 3LCD projector - portable - white
- 3LCD projector - 1080p
- White
- Built-in Devices
- Speaker
- Brightness (White)
- 3400 lumens
- Brightness (Colour)
- 3400 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- Up to 6000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 298 Watt
- 30.2 cm x 25.2 cm x 9.2 cm
- 2.8 kg
- 2-year warranty
- Built-in Devices
- Speaker
- Enclosure Colour
- White
Projector
- 3400 lumens
- 3400 lumens
- Brightness (Reduced)
- 2110 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 1.8 m - 2.17 m
- Throw Ratio
- 1.38 - 1.68:1
- Resolution
- Full HD - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.5 -1.71
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in
- Included Accessories
- Wireless remote control
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Power Source
- AC
- Voltage Required
- 298 Watt
- Power Consumption Stand by
- 0.2 Watt
- 30.2 cm
- 25.2 cm
- 9.2 cm
- 2.8 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 28 dBA
Epson Wireless Adaptor LAN B/G/N | In Stock | £104.30 |
