Epson EB-2042 XGA 3LCD 4400 Lumens Projector
Quicklinx: F5PBWS00 Mfr#: V11H874041
Upgrade your display
Get everyone to sit up and take notice with a display that can reach up to 300 inches. From delivering presentations to streaming box sets at home, experience a display that's up to three times brighter than competitor products, thanks to 3LCD technology . In addition to its bright and vivid colours, the 15,000:1 contrast ratio produces defined shadows and deep blacks.
Myth-busting brightness
Bright rooms are no match for this projector – with 4,400 lumens, this powerful yet affordable model delivers exceptionally bright yet colourful images with clear details. It utilises Epson's renowned 3LCD technology, which produces an equally high White and Colour Light Output.
Long-lasting solution
Durable and affordable, this model's long-lasting lamp light source means you'll be able to project your content every day for six years .
Set up has never been so easy
Keep your cool setting up this hassle-free projector. Keystone correction lets you position the image, while the array of inputs and outputs ensure that it's easy to access content. It includes two HDMI inputs (including one MHL), two VGA in, VGA out, and it's also network enabled via RJ45. Thanks to the optional ELPAP10 adapter, it also offers Wi-Fi connectivity, allowing you to share content from a smart device using the iProjection app.
  • Bright XGA projector
    Experience a bright, high-quality display up to 300 inches in the office or home, and enjoy its wide range of connectivity features.
  • Meet the EB-2042 XGA projector
    Whether you're delivering presentations in the office or watching your favourite shows at home, capture everyone's attention with this bright and high-quality projector that's capable of producing an impressive 300-inch display.Bright rooms are no match for the EB-2042 - with a powerful 4,400 lumens of brightness and 3LCD technology, it can overcome ambient light in the office or at home. Thanks to this technology, it's up to three times brighter than competitor products .This fuss free model is easy to set up and its wide range of connectivity features ensures it's simple to display content quickly. Maintenance is minimal thanks to a long-lasting lamp source.
  • Upgrade your display
    Get everyone to sit up and take notice with a display that can span up to 300 inches. From delivering presentations to streaming box sets at home, it's easy to scale the display to suit the setting and type of content.
  • Bright and vivid
    Why settle for a washed out and lifeless screen? Enjoy bright, vivid colours without it costing the earth. Epson projectors' equally high White and Colour Light Output means your content will always look great,without the need to spend loads on a projector with really high lumens. You can experience vivid and lifelike images with Epson projectors that are up to three times brighter than competitor products .
  • Long-lasting solution
    Durable and affordable, this model's long-lasting lamp light source means you'll be able to project your content every day for six years without needing replacements. With the reliable EB-2042 reliable, you can forget about lamps and air filters and concentrate on the things that matter.
  • No rainbow effect
    1-chip and LED projectors can be subject to the 'rainbow effect', which describes how some people can see a disruptive flicker in fast-moving images. Epson's projectors use 3LCD technology, which means that the 'rainbow effect' can never occur.
  • See details clearly
    Whether you're delivering a presentation and need defined graphs and text, or watching the latest TV series and want to enjoy incredible detail even in atmospheric scenes, this projector's incredible 15,000:1 contrast ratio will deliver with defined shadows and deep blacks.
  • Set up has never been so easy
    Keep your cool setting up this hassle-free projector. It's lightweight at just 3kg, making it simple to move from room to room. Helping you to get up and running, the 1.6x zoom and keystone correction ensure it's quick and easy to align the image.
  • Simple connectivity solutions
    It's straightforward to access content using the wide array of inputs and outputs. There are two HDMI inputs (including one MHL), two VGA in, VGA out, and it's also network enabled via RJ45. Thanks to the optional ELPAP10 adapter, it also offers Wi-Fi connectivity.
  • IProjection
    Epson iProjection is an intuitive mobile projection app for both iOS and Android devices. It makes it easy to wirelessly project images and files, stored on both iOS and Android devices.
Epson EB-2042 - 3LCD projector - LAN - white
3LCD projector
White
Built-in Devices
Speaker
Brightness (White)
4400 lumens
Brightness (Colour)
4400 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
UHE 230 Watt
Bulb life cycle
Up to 5500 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
Video Input
RGB, composite video LAN
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
331 Watt
30.9 cm x 29.3 cm x 105 cm
3 kg
3LCD projector
Built-in Devices
Speaker
Ethernet
Enclosure Colour
White
Projector
Brightness (White)
4400 lumens
Brightness (Colour)
4400 lumens
Brightness (Reduced)
2490 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
76 cm - 762 cm
Throw Ratio
1.38 - 2.24:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz
Bulb type
UHE 230 Watt
Bulb life cycle
Blackboard Mode, EPSON 3LCD technology, Dynamic Mode, Presentation Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x microphone
Wireless remote control, HDMI cable clamp
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
Power Source
AC
331 Watt
Power Consumption Stand by
0.2 Watt
30.9 cm
29.3 cm
105 cm
3 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
28 dBA
F5PB Epson ELPMB23 Projector Mount In Stock £109.44
F5PB Epson Wireless Adaptor LAN B/G/N In Stock £104.30
