Epson EH-TW7400 4K 3LCD 2400 Lumens Projector
Quicklinx: FB5XWS00 Mfr#: V11H932041
Bring the movie theater experience home with this HDR-capable, 4K-enhanced projector, utilizing Epson's technology and 3LCD technology.
  • Easy yet durable set-up
    Watch a movie every day on the big screen for the next seven years thanks to its incredibly long lamp life, which means replacements are few and far between. This projector is designed for ease with motorised optics making installation simple and precise, including a powered 2.1x optical zoom, powered focus and a powered lens shift of ±96.3% vertical and ±47.1% horizontal.
  • Watch your favourite movies as the director intended
    Store up to ten different lens memory positions, so that you can choose the correct aspect ratio at the touch of a button.
Epson EH-TW7400 - LCD projector - 3D - LAN - white
LCD projector - 1080p
3D Capable
Yes (3D glasses sold separately)
White
Brightness (White)
2400 lumens
Brightness (Colour)
2400 lumens
Contrast Ratio
200000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens Shift Direction
Horizontal, vertical
Bulb type
UHE 250 Watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB LAN
355 Watt
52 cm x 45 cm x 19.3 cm
11.2 kg
3D Capable
Ethernet
Enclosure Colour
White
Projector
Brightness (White)
2400 lumens
Brightness (Colour)
2400 lumens
Contrast Ratio
200000:1 (dynamic)
Image Size
127 cm - 762 cm
Projection Distance
3 m - 6.3 m
Throw Ratio
1.35 - 2.84:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
480 Hz
Bulb type
UHE 250 Watt
Bulb life cycle
Side-by-Side, Dynamic Mode, 4K Enhancement, Bright Cinema, Cinema Mode, 3D Dynamic Mode, 3D Cinema Mode, 3D depth adjustment
Lens
Focus Type
Powered
Lens Aperture
F/2.0-3.0
Zoom Type
Powered
Zoom Factor
2.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Vertical Lens Shift
96.3% / 96.3%
Horizontal Lens Shift
47.1% / 47.1%
Video Input
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI
LAN and Wireless Image Transferring Protocols
Wired LAN
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 3 x HDMI - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management)
Remote control, HDMI cable clamp
Security Features
Security Slot Type
Kensington security slot
Power Source
AC
355 Watt
Power Consumption Stand by
0.2 Watt
52 cm
45 cm
19.3 cm
11.2 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours
5 °C
35 °C
Sound Emission
31 dBA
20 dBA
FB5X Epson Wireless Adaptor LAN B/G/N In Stock £98.83
