Introducing the first-ever 3LCD WUXGA projector:
Epson brings you the world´s first dual lamp WUXGA Epson EB-Z8000WU and the new WXGA Epson EB-Z8050W. Both models feature innovative new lamps and 3LCD technology suitable for any large venue or event.
Bringing together 3LCD and optical technology:
Epson brings 20 years of technology to a unique range of high brightness projectors. All 3LCD projectors use a 3-chip, solid-state optical engine to deliver incredibly bright, true-to-life colour, creating an astonishing level of realism. The three colour images are combined using a prism to form a full-colour image consisting of millions of colours. With pure 3LCD plus the powerful 6000 lumens dual lamp system, you enjoy the best picture quality and projector performance.
Colour Light Output, the new metric for projector brightness:
Epson provides Colour Light Output specification data. Colour Light Output measures a projector´s ability to deliver colour, providing users with a simple, accurate and easy way to evaluate projector colour performance.
Epson brings you the world´s first dual lamp WUXGA Epson EB-Z8000WU and the new WXGA Epson EB-Z8050W. Both models feature innovative new lamps and 3LCD technology suitable for any large venue or event. -
Epson brings 20 years of technology to a unique range of high brightness projectors. All 3LCD projectors use a 3-chip, solid-state optical engine to deliver incredibly bright, true-to-life colour, creating an astonishing level of realism. The three colour images are combined using a prism to form a full-colour image consisting of millions of colours. With pure 3LCD plus the powerful 6000 lumens dual lamp system, you enjoy the best picture quality and projector performance. -
- Epson EB-Z8000WU - 3LCD projector - standard lens
- 3LCD projector - 1080p
- Brightness
- 6000 lumens
- Contrast Ratio
- 5000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 16.7 million colours
- Lens
- Standard lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 2 x UHE 330 Watt
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 3500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video
- Digital Video Standard
- Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Video Output
- RGB
- Power
- AC 120/230 V (50/60 Hz)
- 877 Watt
- 53.4 cm x 73.4 cm x 22.5 cm
- 22 kg
- 3-year warranty
Projector
- Brightness
- 6000 lumens
- Brightness (Reduced)
- 4800 lumens
- Contrast Ratio
- 5000:1
- Image Size
- 152 cm - 1270 cm
- Projection Distance
- 4.5 m - 7.3 m
- Throw Ratio
- 1.74 - 2.82:1
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 80 kHz
- Bulb type
- 2 x UHE 330 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Chinese, Korean
- EPSON Quick Corner, Micro Lens Array (MLA) Technology, Noise Reduction, carrying handle, EPSON 3LCD technology, EPSON Cinema Filter, Crystal Clear Fine (C2 Fine)
Lens
- Standard lens
- Focus Type
- Powered
- Lens Aperture
- F/1.65-2.51
- Zoom Type
- Powered
- Zoom Factor
- 1.61x
- Keystone Correction Type
- Optical
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -20 / +20
- Lens Shift Type
- Powered
- Vertical Lens Shift
- 70% / 70%
- Horizontal Lens Shift
- 20% / 20%
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video, DVI
- Video Modes
Video Output
- Analogue Video Signal
- RGB
Input Device
- External
- 1 x HDMI - 19 pin HDMI Type A , 1 x DVI-D - 24+1 pin digital DVI , 1 x component video input - BNC x 5 , 1 x composite video input - BNC , 1 x S-video input - 4 pin mini-DIN , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x remote control (management)
- Included Accessories
- Lens cover, cable cover, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Mounting Kit
- Optional
- Security Features
- Security lock slot (cable lock sold separately), password protection, control panel lock
- Voltage Required
- 877 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- 53.4 cm
- 73.4 cm
- 22.5 cm
- 22 kg
- Limited warranty - 3 years
- 0 °C
- 45 °C
- Sound Emission
- 38 dB
- Sound Emission (Economic Mode)
- 32 dB
