Bright, vivid content on a large scalable screen
Enjoy large scale presentations with crisp, clear text, as well as compelling imagery and video content on screen sizes up to 320 inches. 3,500-lumen performance combines with a high contrast ratio of 15,000:1 to offer outstanding visual performance, even in well-lit rooms.
Years of uninterrupted meetings
With a lamp life and air filter maintenance cycle of 12,000 hours in eco mode, users won't need to worry about maintenance for more than 5 years .
Installation and placement flexibility
Automatic vertical and manual horizontal keystone correction provide greater flexibility as to where the projector can be placed in the room for distortion-free images and the wide optical zoom adds to the flexibility.
Network and Wi-Fi capability
Wi-Fi compatibility and network capability (via RJ45) mean the EB-W39 can be added to a company network or upgraded for wireless device access at a later stage (optional accessory required).
High-quality sound
This projector has a built-in 5W speaker to allow audio content to be heard clearly, without the need for additional external speakers.
Flexible HD-Ready projector
With detailed WXGA resolution and the versatility to be positioned just about anywhere, this durable projector will provide years of service.
- Epson EB-W39 - 3LCD projector - portable - LAN - grey, white
- 3LCD projector - 720p
- Grey, white
- Built-in Devices
- Speaker
- Brightness (White)
- 3500 lumens
- Brightness (Colour)
- 3500 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 315 Watt
- 30.2 cm x 24.9 cm x 9.2 cm
- 2.7 kg
- 3-year warranty
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Enclosure Colour
- Grey, white
Projector
- 3500 lumens
- 3500 lumens
- Brightness (Reduced)
- 2280 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 84 cm - 813 cm
- Throw Ratio
- 1.3 - 1.56:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Crestron Connected, Eco Mode, Extron Control System, AMX Control System, document camera compatible
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.58-1.72
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 5 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x HDMI - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Power Source
- AC
- Voltage Required
- 315 Watt
- Power Consumption Stand by
- 0.2 Watt
- Software Included
- EasyMP Network Projection, EasyMP Multi PC Projection
- 30.2 cm
- 24.9 cm
- 9.2 cm
- 2.7 kg
- Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 28 dBA
Epson ELPMB23 Projector Mount | In Stock | £109.44 |
Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) | In Stock | £101.71 |
