Epson EB-1975W 5000 Lumens WXGA LCD Projector
Quicklinx: B3J4WS00 Mfr#: v11h621041
High quality
Professional environments are treated to presentations in more detail than ever before thanks to the EB-1975W's WXGA resolution, which fits the resolution and aspect ratio of most laptops. That detail shines through, even in daylight, thanks to 5,000 lumens brightness.
More vivid colours
Epson's own 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors .
Easy to set up
Focus help, keystone correction and screen fit modes are included to ensure that set-up is simple, while flexible connectivity options include two HDMI ports, Wi-Fi and wired LAN.
Share content
With Miracast and WiDi, the EB-1975W can easily stream content from, and mirror the screen of, a range of smart devices, and is compatible with Epson's iProjection app . Content, such as a multi-source video conference and presentations, can be displayed in split-screen, while Multi-PC Projection software supports up to 50 PCs for collaboration in large meetings.
Built-in speakers
Epson recognises that video is being used more often within presentations, so as well as a high-resolution image, this business projector also includes built-in 16W speakers.
  • Bright business projector
    WXGA resolution, 5,000 lumens of brightness and 3LCD technology help make the EB-1975W ideal for any meeting room.
Epson EB-1975W - 3LCD projector - 802.11n wireless / LAN
3LCD projector
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
280 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, composite video, component video IEEE 802.11n wireless / LAN
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
37.7 cm x 29.2 cm x 12.5 cm
4.5 kg
3-year warranty
3LCD projector
802.11b/g/n
Projector
Brightness (White)
5000 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
0.9 m - 14.8 m
Throw Ratio
1.38 - 2.28:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
280 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Split Screen, 16:10 aspect ratio support, DICOM Simulation Mode, Dynamic Mode, Theater Mode, MHL compliance
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, MHL
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type B
Remote control
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
37.7 cm
29.2 cm
12.5 cm
4.5 kg
Limited warranty - 3 years / 8000 hours - carry-in , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
39 dB
32 dB
B3J4 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
