Epson 3800 ANSI Lumens WUXGA 3LCD UST Interactive Projector
Quicklinx: CMT0WS00 Mfr#: V11H771041
Any meeting room can benefit from interactivity with the ultra-short-throw projector, featuring dual pen capability, a high brightness level of 3,800 lumens, Full HD WUXGA resolution and remote multi-location connectivity. The ultrashort-throw EB-1440Ui is designed to present a scalable screen size of up to 100 inches to deliver the requirements of any business working environment.
  • Up to 100-inch display and outstanding quality
    Full HD WUXGA resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity also means that the audience benefits from sharper and clearer content displayed in any meeting room environment.
  • All-in-one office solution
    This interactive meeting room solution combines the benefits of flipcharts, whiteboards and conventional screens into one unified meeting room solution. Meeting participants can view and annotate whiteboard content from a range of smart devices, without the need for any special application, ensuring information remains secure with the ability to apply passwords to meetings and notes. The remote desktop feature promotes freedom from the desktop – simply leave your PC, including those running Windows 10, on your desk and present from anywhere around the office. Take advantage of Skype in business and other video call solutions during meetings.
  • Dual pen
    Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, colleagues can work simultaneously using different pen attributes.
  • Sliding split screen
    Combine two sources and project, such as multi-source video conference and presentation, to optimise interaction.
  • Wireless connectivity
    Share content easily from a range of smart devices using the iProjection App.
Epson EB-1440Ui - 3LCD projector - 802.11n wireless / LAN - white
3LCD projector - 1080p
White
Built-in Devices
Speaker
Brightness (White)
3800 lumens
Brightness (Colour)
3800 lumens
Contrast Ratio
300:1 / 16000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
267 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video IEEE 802.11n wireless / LAN
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
401 Watt
47.4 cm x 44.7 cm x 13 cm
8.4 kg
3-year warranty
Built-in Devices
Speaker
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
3800 lumens
Brightness (Colour)
3800 lumens
Brightness (Reduced)
2900 lumens
Contrast Ratio
Image Size
178 cm - 254 cm
Projection Distance
0.4 m - 0.6 m
Throw Ratio
0.27 - 0.37:1
Digital Zoom Factor
1.35x
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Bulb type
267 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Direct Power On, Direct Power Off, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode, Auto Calibration
Lens
Focus Type
Manual
Lens Aperture
F/1.6
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-3 / +3
Horizontal Keystone Correction
-3 / +3
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI input - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x DVI-D output - 24+1 pin digital DVI , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out , 1 x serial RS-232C , 1 x composite video input - RCA
Wall mounting kit, wireless remote control, wireless LAN unit, pen case, interactive pens, pen tips
1 x USB cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
401 Watt
Power Consumption Stand by
0.5 Watt
Software Included
Epson Easy Interactive Tools, EasyMP Monitor, EasyMP Multi PC Projection
47.4 cm
44.7 cm
13 cm
8.4 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
30 dBA
