The Eaton 5130 Rack Tower UPS provides line-interactive backup power and scalable runtimes for servers, storage systems, VoIP gear and network equipment. With a two-in-one rack/tower form factor. To enhance compatibility with modern IT loads, the 5130 UPS is designed with a 0.9 power factor.
- Eaton PW5130i3000-XL3U - UPS - 2.7 kW - 3000 VA
- UPS - external
- Rack Size
- 3U
- 34.3 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 184-265 V
- Power Capacity
- 2.7 kW / 3000 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
- Battery
- Lead Acid - 7.2 Ah
- Battery Form Factor
- Internal
- Run Time (Up To)
- 3 min at full load
- Networking
- RS-232, USB
- Included Accessories
- Screwdriver, tower stand, cable retention brackets
- 44.1 cm x 48.4 cm x 13.07 cm
- 3 years warranty with product registration
- UPS - external
- Battery Enclosure Type
- Internal
- Height (Rack Units)
- 3U
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 294 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 184-265 V
- Power Capacity
- 2.7 kW / 3000 VA
- Surge Suppression
- Efficiency
- 94%+
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 7.2 Ah
- Run Time (Up To)
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - RJ-45 , 1 x management (USB) - 4 pin USB Type B
- Expansion Slots
- 1 Communication slot
- Cables Included
- Serial cable - external , USB cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LED indicators, over voltage protection, undervoltage protection
- FCC Class A certified, UL, TUV, C-Tick, ANSI C62.41, cUL, UL 1778, UL 497A, IEC 60950, FCC Part 15, EN 50091-2, CSA C22.2 No. 107.1, EN 50091-1
- Software Included
- Eaton Intelligent Power Software Suite
- Limited warranty - parts and labour - 3 years
- 0 °C
- 35 °C
- 20 - 95% (non-condensing)
- Sound Emission
- 45 dB
- 44.1 cm
- 48.4 cm
- 13.07 cm
- 34.3 kg
