DrayTek Vigor 2920n Dual-WAN Router with 802.11n Wi-Fi
Quicklinx: 74TJWS00 Mfr#: V2920N
  • IEEE 802.11n
1 on order, delivery delayed
The Vigor2920n is firewall broadband routers for connecting to Cable/VDSL2/Ethernet FTTx. The Gigabit WAN and 4-port Gigabit LAN switch facilitates unified communication applications in business CO/remote site to handle large data from subscribed higher speed broadband. The state-of-art router feature, VPN, security, dual WAN provides integrated benefits for professional users and small offices.
Its well-structured Web User Interface (WUI) offers user-friendly configuration and allows specific setting to satisfy users' various needs. The WUI also provides IP layer QoS (Quality of Service), NAT session/bandwidth management to help users control and allocate the bandwidth on networks.
In short, the WUI of Vigor2920 series give you a nice and smooth way to operate all enrich features you need.
Draytek Vigor 2920n - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Performance
VPN throughput (IPSec): 40 Mbps
VPN tunnels: 32
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, PPPoE, DHCP
Routing Protocol
RIP-2, static IP routing
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, FTP, TFTP, SSH, CLI
Firewall protection, DHCP support, VLAN support, Syslog support, SPI, DoS attack prevention, content filtering, dynamic DNS server, E-mail alert, MAC address filtering, VPN passthrough, WDS support, URL filtering, Outbound Load Balancing, firmware upgradable, DDos attack prevention, WMM support, QoS, DPD, IPSec NAT-T, WPS, WAN failover, DHCP server, Multiple SSID support, hidden SSID, BOD
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup
16.5 cm x 24.1 cm x 4.4 cm
Enclosure Type
Desktop
Wireless, wired
Performance
VPN tunnels: 32
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
Authentication Method
RADIUS, X.509 certificates, Radio Service Set ID (SSID)
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup, FCC
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
10 Watt
16.5 cm
24.1 cm
4.4 cm
45 °C
10 - 90%
Get the most from your Router
74TJ DrayTek Rack Mount Bracket For Vigor 2830, 2850, 2920, 2930 In Stock £35.00
