DrayTek Vigor 2862Lac LTE Wireless AC Router
Quicklinx: DHPRWS00 Mfr#: V2862LAC-K
  • IEEE 802.11n
The Vigor 2862L features the same specification as the standard Vigor2862 product with the addition of built-in 4G (Cellular/LTE) connectivity, compatible with all UK/Ireland cellular networks. The embedded 4G/LTE connectivity provides a self-contained solution as opposed to having to add external/USB modems to your router. A standard SIM slot on the back of the router is secured with a cover to prevent accidental removal.
As well as connectivity to the 4G (LTE) networks, the Vigor 2862L series provides backward compatibility to 3G networks for areas or networks where 4G isn't available. Full function MS message operation also provides additional functionality and control.
Secondary or backup 3G/4G connectivity, using a second network/SIM can be added by the use of an additional 3G/4G USB modem. Check the compatibility list to see which USB modems are supported. Alternatively, using Wireless WAN, the Vigor 2862L can derive a secondary WAN (Internet) connection from a WiFi feed - e.g. your mobile phone's hotspot or a temporary mobile provision.
The Vigor 2862L series also provides built-in ADSL/VDSL and Ethernet WAN connectivity for wired (broadband) Internet connections.
Draytek Vigor 2862L - wireless router - DSL/WWAN - Wi-Fi 5 - desktop
Wireless router - DSL modem / wireless cellular modem - 5-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+, VDSL2
Mobile Communication Protocol
GSM, GPRS, UMTS, HSDPA, HSPA+, LTE
WAN Ports Qty
4
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Maximum number of configured SSIDs: 4 , Maximum number of users: 200 , VPN tunnels: 32 , LAN clients: 1022
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, FTP, DHCP
Routing Protocol
RIP-2, static IP routing, GRE, policy-based routing (PBR), RIPng
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI, NTP
DMZ port, load balancing, Syslog support, Stateful Packet Inspection (SPI), dynamic DNS server, port mirroring, DiffServ support, MAC address filtering, VPN passthrough, High Availability, Wireless Distribution System (WDS) support, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), WAN failover, Multiple SSID support, SMS alert, hidden SSID, Bandwidth-On-Demand (BOD), port forwarding, DHCP relay, DHCP client, DNS caching, Content Security Management (CSM), 802.1x authentication, beamforming technology, Management Information Base (MIB) II, band steering, failover protection, 4x4 MU-MIMO technology, Denial of Service (DoS) protection, DMZ support, VLAN Tagging, port-based VLAN, PPPoA client, PPPoE client
IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, IEEE 802.11e, UPnP
AC 230V
24.096 cm x 16.507 cm x 4.396 cm
United Kingdom
Wireless router - 5-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, IKE, SHA-1, WPA2, 128-bit AES, 192-bit AES, 256-bit AES, 256-bit SHA
Authentication Method
RADIUS, Radio Service Set ID (SSID), TACACS+, LDAP
Status Indicators
Power, WAN, link/activity, USB, VPN, LTE, DSL
Line Properties
Framing Format
ANSI T1.413
Communications
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.997.1, ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Antenna: 2 x SMA , WAN: 1 x VDSL / ADSL over ISDN - RJ-11 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 2 x USB 2.0
Expansion Slots
1 (total) / 1 (free) x SIM
Aerial
Aerial
External
Antenna Qty
2
External power adapter
AC 230V
18 Watt
Rack Mounting Kit
Optional
United Kingdom
24.096 cm
16.507 cm
4.396 cm
45 °C
10 - 90% (non-condensing)
