The Vigor2820 is an ADSL2+ router with 2nd Ethernet WAN. This 2nd WAN can connect to DSL/Cable modem or fiber media converter for policy-based load-balance, fail-over and BoD, it also features advanced bandwidth control mechanisms such as IP-layer QoS, NAT Session Limitation, Bandwidth Borrowed, etc., to allow easy, flexible and reliable access control and bandwidth management.
- Draytek Vigor 2820 - router - DSL modem - desktop
- Router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+, READSL
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, ATM, Fast Ethernet, Gigabit Ethernet
- Capacity
- VPN tunnels: 32
- PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, AAL5, DHCP, DNS
- Routing Protocol
- RIP-2, static IP routing
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, SSH
- Firewall protection, DMZ port, DHCP support, NAT support, Syslog support, SPI, content filtering, dynamic DNS server, E-mail alert, VPN passthrough, firmware upgradable, DDos attack prevention, QoS
- ANSI T1.413, IEEE 802.1x, UPnP
- 16.5 cm x 24.1 cm x 4.4 cm
- 2-year warranty
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Capacity
- VPN tunnels: 32
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
- Authentication Method
- X.509 certificates, Radio Service Set ID (SSID)
- ANSI T1.413, IEEE 802.1x, UPnP, FCC
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5
- WAN: 1 x ADSL2+ - RJ-11 , 3 x 10Base-T/100Base-TX - RJ-45 , 1 x 1000Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 4 pin USB Type A
- Power Device
- External power adapter
- 10 Watt
- 16.5 cm
- 24.1 cm
- 4.4 cm
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90%
Customer reviews
Write a review for the DrayTek Vigor 2820 Router/Firewall - Wired here!
Great Product
Reviewed by Mark. Review Posted 30/04/2008
This is a great product for advanced users. Lots of options and allows you to load balThis is a great product for advanced users. Lots of options and allows you to load balance cable and ADSL! <br /><br /> The Draytek website has a few more up-to date firmware upgrades that enables the 3G connection: http://www.draytek.co.uk/support/downloads.html. <br /><br /> Full spec here: http://www.draytek.co.uk/products/vigor2820.html (note: this model doesnt have VOIP).
Overall
Ease of use
Value for money
Good make can still have gremlins
Reviewed by Anonymous Review Posted 12/06/2008
I have been through many makes of Routers but settled on Draytek for a while now. This time I was let down. The router has worked for about 15 minutes before going into a reboot loop. Shame that this was on a job & now I have more expence than orignally planned.
However, I'm still behind Draytek on their well priced and feature rich routers that generally do not break.
Overall
Ease of use
Value for money
Let's be realistic
Reviewed by Mr P. Review Posted 02/08/2008
Most people who have had anything to do with ADSL in a business know Draytek. The immediate stop of the 2800 was a shame as after many bugs initially it worked. But you now have the feature rich 2820 with an ADSL load balance/ADSL fail backup and surprisingly it works. I manage over 80 ADSL at work and all have a Drayteks (mostly because there is no one else). If you get one that works first time your lucky. I have never met one that didn’t have a “character”. The 2820 is faster to remote manage, looks just like the 2800. The only bug I have found. Remote users. If the Draytek is your DHCP an IP conflict is created as it won’t allocate the correct ip range, namely above 200 as default. The most recent firmware doesn’t fix the problem. You also have some VPN routing issues for the dial in users. So watch out. Some initially restart and stay off for approx 20mins. But leave it alone, it comes back on and never happens again. Odd! Characters!
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
