Draytek Vigor 2830n Wireless ADSL Router Firewall & 4 Port Switch
Quicklinx: 7LLJWS00 Mfr#: V2830N-K
  • IEEE 802.11n
The Vigor 2830 series is DrayTek's flagship premium ADSL router/firewall family with support for professional features such as VLAN tagging and Gigabit Ethernet. Compatible with all variants of ADSL (including ADSLMax, ADSL2+ and Annex M) the Vigor 2830 can be used for cable-modem and leased line applications using its additional gigabit ethernet WAN port. A four port Gigabit switch on the LAN side provides high speed connectivity for your server or other local PCs, for the highest speed local data transfer. Security features include content filtering, web application controls and object based firewall management system.
Robust & Comprehensive Firewall
Security is always taken seriously with DrayTek routers. The firewall protects against attacks including DoS (Denial of Service) attacks, IP-based attacks and access by unauthorised remote systems. Wireless, Ethernet and VPN are also protected by various protection systems. The latest ('Version 3') DrayTek object-based firewall allows even more setup flexibility than ever, enabling you to create combinations of users, rules and restrictions to suit multi-departmental organisations. The Vigor 2830 now also allows selective direction firewall rules of LAN to WAN, WAN to LAN or LAN to VPN. In addition, QoS (Quality of Service Assurance) can now be selectively applied to specific users.
IPv6 - Next Generation Internet Routing
The Vigor 2830 now supports IPv6 - the successor to the current IPv4 addressing system that has been used since the Internet was first created. IPv4 address space is full up and IPv6 allows for much more efficient routing and a larger address space. IPv6 is supported both from your own ISP, but if your ISP does not (yet) support IPv6, the Vigor 2850 also supports IPv6 broker/tunnel services to provide IPv6 access using either TSPC or AICCU via 3rd party IPv6 providers. To learn all about IPv6, you can get our book here.
IPv6 on the Vigor 2830 provides the following features:
  • IPv6 support DrayTek Vigor 2830
  • Operation on any one of the WAN ports (WAN1 ADSL, WAN2 Ethernet or 3G)
  • Connectivity to direct native IPv6 ISPs
  • Built-in tunnelling to 3rd party IPv6 brokers
  • supporting TSPC or AICCU methods
  • Default stateful firewall for all IPv6 LAN Clients/Devices
  • DHCPv6 Client or Static IPv6 Client
  • DHCPv6 & RADVD for client configuration
  • IP Filtering Rules
  • QoS for IPv6 with DiffServ
  • Router Management over IPv6 (Telnet/HTTP) with IPv6 Access List
  • Simultaneous (concurrent) operation with IPv4 ("Dual-Stack")
  • Other router features are available on IPv4 only currently
Web Content Filtering
The Content control features of the Vigor 2830 allow you to set restrictions on web site access, blocking download of certain file or data types, blocking specific web sites with whitelists or blacklists, blocking IM/P2P applications or other potentially harmful or wasteful content. Restrictions can be per user, per PC or univeral. Using DrayTek's GlobalView service, you can block whole categories of web sites (e.g. gambling, adult sites etc.), subject to an annual subscription to the Globalview service, which is continuously updated with new or changed site categorisations or sites which have become compromised (such as infected with Malware). A free 30-day trial is included with your new router.
  • Robust & comprehensive firewall
    Security is always taken seriously with DrayTek routers. The firewall protects against attacks including DoS (Denial of Service) attacks, IP-based attacks and access by unauthorized remote systems. Wireless, Ethernet and VPN are also protected by various protection systems. The DrayTek object-based firewall allows even more setup flexibility than ever, enabling you to create combinations of users, rules and restrictions to suit multi-departmental organizations. In addition, QoS (Quality of Service Assurance) can now be selectively applied to specific users. The content control features of the Vigor 2830 allow you to set restrictions on web site access, blocking download of certain file or data types, blocking specific web sites, blocking IM/P2P applications or other potentially harmful or wasteful content.
  • Triple-WAN load balancing & backup
    As well as the primary ADSL (WAN) interface, the Vigor 2830 features two other WAN connections. WAN2 is Ethernet and WAN3 is a USB port for connection of a 3G modem. WAN2 can connect to a second ADSL modem, a cable modem or any other Ethernet-based Internet feed. The multiple WAN interfaces can be used either for WAN-backup or load balancing. WAN-backup provides contingency in case of your primary ADSL line or ISP suffering temporary outage. Internet traffic will be temporarily routed via the secondary Internet access. When normal services is restored to your primary ADSL line, all traffic is switch back to that.
Draytek Vigor 2830n - wireless router - DSL - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Concurrent VPN tunnels : 32 , NAT/ firewall sessions : 60000
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, FTP, DHCP, DNS, DDNS
Routing Protocol
RIP-2, static IP routing, IGMPv3
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, CLI
Firewall protection, DHCP support, NAT support, VPN support, load balancing, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, DiffServ support, E-mail alert, print server, MAC address filtering, URL filtering, firmware upgradable, DDos attack prevention, wall mountable, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, X.509, IEEE 802.11e, IEEE 802.11n
AC 230V
16.5 cm x 24.1 cm x 4.4 cm
2 years warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
Authentication Method
RADIUS, X.509 certificates
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5
LAN : 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB : 1 x 4 PIN USB Type A , WAN : 1 x ADSL2+ - RJ-11 , WAN : 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
3
Power adapter - external
AC 230V
18 Watt
16.5 cm
24.1 cm
4.4 cm
CE, FCC, X.509
2 years warranty
Service & Support Details
45 °C
10 - 90% (non-condensing)
Get the most from your Router
7LLJ DrayTek Rack Mount Bracket For Vigor 2830, 2850, 2920, 2930 In Stock £35.00
