Dell PowerConnect W-IAP225 Radio Access Point 802.11a/b/g/n
Quicklinx: BTQLWS00 Mfr#: 210-ABEQ
  • IEEE 802.11n
Multifunctional 220 series wireless APs deliver gigabit WiFi performance to 802.11ac mobile devices. Integrated ClientMatch technology ensures consistently high performance across the WLAN infrastructure.
With a maximum data rate of 1.3 Gbps in the 5 GHz band and 600 Mbps in the 2.4 GHz band, 220 series APs are three times faster than 802.11n APs and provide performance similar to a wired connection. The 220 series APs include ClientMatch technology, which eliminates sticky clients by continuously gathering session performance metrics from mobile devices. This information is then used to steer each mobile device to the best AP and radio on the WLAN.
Proactive and deterministic, ClientMatch dynamically optimizes Wi-Fi client performance as users roam and RF conditions change. If a mobile device moves out of range of an AP or RF interference impedes performance, ClientMatch automatically steers it to a better AP.
With ClientMatch, 220 series APs load web pages faster, deliver video streams with improved quality and support high densities of mobile devices. An 802.11ac network without ClientMatch performs no different than an 802.11n WLAN. The 220 series APs additionally support priority handling and policy enforcement for individual Microsoft Lync media on the same device, including encrypted videoconferencing, voice, chat and desktop sharing.
Dell PowerConnect W-IAP225 - radio access point - Wi-Fi 5
Radio access point
External - indoor
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Mounting brackets
Power Over Ethernet (PoE) Supported
PoE+
20.3 cm x 20.3 cm x 5.4 cm
750 g
Radio access point
Ruggedized Design
Indoor
20.3 cm
20.3 cm
5.4 cm
750 g
United Kingdom
External
Wireless
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, system, WLAN, LAN
Auto-sensing per device, load balancing, auto-uplink (auto MDI/MDI-X), Wireless Intrusion Detection System (WIDS), IPSec Virtual Private Network (VPN), Trusted Platform Module (TPM), reset button, Adaptive Radio Management (ARM), 3T3R MIMO technology, Energy Efficient Ethernet
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.3ac, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az
Aerial
Antenna
Internal
Antenna Qty
6
Directivity
Omni-directional
2 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 1 x USB 2.0 - Type A
Mounting brackets
EN 60950, IEC 60950, UL 60950, CB, UL 2043, FCC, R&TTE, cTUVus, EN 300 328, EN 301 893
PoE+
OS Provided
ArubaOS
Limited warranty - lifetime
50 °C
5 - 95% (non-condensing)
BTQL C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
BTQL C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.65
