Dell PowerConnect W-AP105 Radio Access Point 802.11a/b/g/n
Quicklinx: BTQBWS00 Mfr#: 210-37295
  • IEEE 802.11n
The multifunction Dell PowerConnect W-AP92 and W-AP93 are entry-level indoor, single-radio 802.11n access points (APs) designed for low-density deployments in offices, hospitals, schools and retail stores. These compact, high-speed APs deliver wire-like performance at data rates up to 300 Mbps. The W-AP Access Points and W-Series Controllers complement Dell's existing PowerConnect portfolio of networking solutions, and securely and efficiently extend wired network capabilities to the mobile workforce.
  • Wire-like performance
    The multifunction PowerConnect W-AP105 is an affordable indoor 802.11n access point (AP) designed for high-density deployments in offices, hospitals, schools and retail stores. The compact, high-speed W-AP105 delivers wire-like performance at data rates up to 300 Mbps. 802.11n enables the use of wireless as a primary connection with speed and reliability comparable to a wired LAN. It can also increase performance by utilizing such techniques as channel bonding, block acknowledgment and multiple-input, multiple-output (MIMO) radios. Advanced antenna technology helps increase range and reliability.
  • Enhance your wireless mobility
    Access layer networks of the past were not built for today's distributed enterprises. Traditionally, networks were built with a focus on individual ports and physical locations rather than on the capability of the user or device to connect to the network. Dell's architecture enables a wireless user to securely access the enterprise network with a consistent, "always-on" experience with the Dell PowerConnect W-AP105 Access Point. Uniform security and access control policies are applied to users in headquarters, branch offices, home offices or on the road. Users and devices securely connect to a Dell controller installed in the enterprise network core. The controller directly controls Dell PowerConnect W-Series access points, managing their configuration, user connection state and policy enforcement.
  • State-of-the-art RF management
    Dell's Adaptive Radio Management (ARM) technology can adjust how Wi-Fi clients interact and help ensure that data, voice and video applications have sufficient network resources to operate properly, delivering a great wireless experience for end users.
  • High-definition video and toll-quality voice
    Dell's PowerConnect W-Series of access points and centralized controllers offer high-definition quality video and toll-quality voice across the wireless infrastructure.
Dell PowerConnect W-AP105 - radio access point - Wi-Fi
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
13.5 cm x 13.2 cm x 4.5 cm
300 g
1-year warranty
Radio access point
Ruggedized Design
Indoor
13.5 cm
13.2 cm
4.5 cm
300 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, wall mountable, Mesh networking, Wi-Fi Multimedia (WMM) support, Trusted Platform Module (TPM), Adaptive Radio Management (ARM), 3T3R MIMO technology
Encryption Algorithm
WPA, WPA2
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
VCCI, EN 60950, NOM, IEC 60950, UL 60950, CB, CCC, IC, MIC, UL 2043, FCC, R&TTE, KCC, ANATEL, cTUVus, LVD, SRRC, Directive 72/23/EEC, EN 300 328, EN 301 893
PoE+
12.5 Watt
OS Provided
ArubaOS
Limited warranty - 1 year
50 °C
5 - 95% (non-condensing)
BTQB C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
