The Dell PowerConnect W-3200 controller is a full-featured, integrated mobility access controller that addresses a wide range of wireless network mobility, security and remote networking requirements for small and branch enterprise deployments.
Integrated access controller
PowerConnect W-3000 series controllers act as headend devices for enterprise wireless networks that use central controllers to manage complex, processing-intensive management and security functions. PowerConnect W-series access points virtualized and implement wireless LAN services and move user traffic to the controllers through secure IP tunnels over a public or private transport network. -
Hassle-free, dependable deployment
The PowerConnect W-series Adaptive Radio Management (ARM) technology helps optimize client behavior using infrastructure-based controls that utilize information from the centrally managed WLAN controller. ARM can adjust how Wi-Fi clients interact and verify that data, voice and video applications have sufficient network resources to deliver a superior wireless experience for end users. -
Integrated wireless security
The PowerConnect W-series controllers are an integrated wireless security platform that supports user authentication and policy enforcement, firewall, intrusion protection and centralized encryption. -
User-centric network management
PowerConnect W-Airwave Wireless Management Suite (AWMS) is an operations solution that manages wired and wireless infrastructure as well as mobile devices.
- Dell PowerConnect W-3200 - network management device
- Network management device
- Form Factor
- External
- Ports Qty
- 4
- Data Link Protocol
- Performance
- Firewall throughput: 3 Gbps , 3DES throughput: 1.6 Gbps , AES throughput: 800 Mbps
- Capacity
- Maximum number of access points: 32 , Maximum number of access points (remote): 128 , User licences: 2048 , MAC addresses: 64000 , Active firewall sessions: 128000 , Concurrent IPSec tunnels: 2048 , Virtual interfaces (VLANs): 256 , IPv4 routes (Unicast): 2048 , Maximum number of configured SSIDs: 256
- Power
- AC 90 - 264 V (47 - 63 Hz)
- 35.1 cm x 29.7 cm x 4.4 cm
- 3.2 kg
- 1-year warranty
- 35.1 cm
- 29.7 cm
- 4.4 cm
- 3.2 kg
- Enclosure Colour
- Black
- Form Factor
- External
- Ports Qty
- 4
- Connectivity Technology
- Wired
- Performance
- Capacity
- Encryption Algorithm
- Triple DES, AES-CCM
- 1 x management (RS-232) - RJ-45 , 4 x 1000Base-T - RJ-45 , 4 x 1000Base-X - SFP (mini-GBIC)
- C-Tick, CISPR 22 Class A, EN 60950, GS, NOM, EN55024, EN55022 Class A, UL 60950, CB, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, MIC, AS/NZS 3548, EN 61000-4-5, EN 61000-4-11, EN 61000-4-8, FCC Part 15 A, ANATEL, cTUVus, CAN/CSA C22.2 No. 60065, VCCI Class A, EN 61000-3
- Power Device
- External power adapter
- Voltage Required
- 35 Watt
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
