Built to help keep operating costs down, the N1100 series can operate at a wide range of temperatures to help reduce cooling costs. With high throughput and capacity to handle unexpected workloads, the N1100 series switches are ideal solutions for fast-growing GbE networks that require high-density aggregation with seamless redundancy and availability.
Designed for efficiency
Built to help keep operating costs down, the N1100 series can operate at a wide range of temperatures to help reduce cooling costs. -
Deploy with confidence
- Dell EMC Networking N1148T-ON - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed - stackable
- Enclosure Type
- Front to back airflow rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x 10 Gigabit SFP+
- Performance
- Switching capacity (full duplex): 176 Gbps , Forwarding rate: 132 Mpps
- Capacity
- MAC addresses: 16000 , LAG groups: 64 , Virtual interfaces (VLANs): 512 , ARP entries: 2048 , NDP entries: 400 , ACL rules: 4000 , Buffer capacity (MB): 4
- MAC Address Table Size
- 16000 entries
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, TFTP
- Flow control, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, IPv6 support, Rapid Spanning Tree Protocol (RSTP) support, Per-VLAN Spanning Tree Plus (PVST+), IPv4 support, LLDP support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), Dynamic VLAN Support (GVRP), redundant fans
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- 43.18 cm x 25.4 cm x 4.445 cm
- 3.78 kg
- Limited lifetime warranty
- Enclosure Type
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16000 entries
- Routing Protocol
- Encryption Algorithm
- AES, SSL, TLS 1.0
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- RAM
- 1 GB
- Flash Memory
- 1 GB
- 48 x Gigabit LAN RJ-45 , 4 x 10Gbit LAN SFP+ , 1 x USB Type A , 1 x console (micro-USB)
- Power Device
- Internal power supply
- Installed Qty
- 1
- Power Provided
- 60 Watt
- 30.18 Watt
- Cables Included
- 1 x micro-USB to USB cable
- Rack Mounting Kit
- Included
- FCC Class A certified, UL, cUL, GS, EMC, RoHS, WEEE, REACH, ICES Class A, NRTL, VCCI Class A, EAC, CCC Class A, FDA 21CFR1040.10, FDA 21CFR1040.11, NAL, ACMA RCM
- 43.18 cm
- 25.4 cm
- 4.445 cm
- 3.78 kg
- Limited warranty - parts - lifetime
- 0 °C
- 45 °C
- 0 - 95%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 65 °C
- Humidity Range Storage
- 0 - 85%
