All N-series switches are designed for easier deployment, greater interoperability and a lower learning curve for network administrators.
                Robust securityEquipped with AES, SSL, and TLS 1.0 encryption algorithms, this Dell Networking switch ensures secure data transmission across the network, safeguarding sensitive information against unauthorized access.
                High capacityWith support for up to 16,000 MAC addresses, 512 VLANs, and 4,000 ACL rules system-wide, the N1148P-ON is designed to meet the demands of large-scale networks, ensuring efficient management and seamless operation.
                Enhanced connectivityFeaturing 48 Gigabit Ethernet ports, including 24 with PoE+ capability, and 4 additional 10 Gigabit SFP+ ports, this switch offers versatile connectivity options for a wide range of devices and applications.
                Optimized performanceThe switch boasts a switching fabric bandwidth of 176 Gbps and a forwarding performance of 132 Mpps, enabling high-speed data processing and transmission for improved network efficiency and performance.
                Comprehensive standards complianceCompliant with a broad array of standards including IEEE 802.3, IEEE 802.1Q, and more, the N1148P-ON ensures interoperability and reliable operation within diverse networking environments.
- Dell Networking N1148P-ON - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed - stackable
- Enclosure Type
- Front to back airflow rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (24 PoE+) + 4 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 375 W
- Performance
- Switching fabric bandwidth: 176 Gbps , Forwarding performance: 132 Mpps
- Capacity
- MAC addresses: 16000 , Aggregated links (dynamic): 144 , LAG groups: 64 , Queues per port: 8 , VLANs supported: 512 , ARP entries: 2048 , NDP entries: 400 , Max ACL rules system-wide: 4000 , ACL: 100 , Maximum ACL rules per interface (IPv4) ingress rules: 1023 , Maximum ACL rules per interface (IPv4) egress rules: 1023 , Maximum ACL rules per interface (IPv6) ingress rules: 1021 , Maximum ACL rules per interface (IPv6) egress rules: 253
- MAC Address Table Size
- 16000 entries
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 2, SNMP, RMON, Telnet, HTTP, TFTP, SSH-2
- Layer 2 switching, MDI/MDI-X switch, auto-negotiation, port mirroring, IP address filtering, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, Remote Switch Port Analyzer (RSPAN), Management Information Base (MIB), dual firmware images, redundant fans, MAC and IP-based ACLs support, Time-controlled ACLs support
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, ANSI/TIA-1057, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.3ax
- 43.2 cm x 25.4 cm x 4.45 cm
- 4.17 kg
- Limited lifetime warranty
- Enclosure Type
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 375 W
- Performance
- Capacity
- 16000 entries
- Routing Protocol
- Encryption Algorithm
- AES, SSL, TLS 1.0
- Authentication Method
- RADIUS, TACACS+, LDAP
- RAM
- 1 GB
- Flash Memory
- 1 GB
- 24 x Gigabit LAN RJ-45 , 24 x Gigabit LAN RJ-45 PoE+ , 4 x 10Gbit LAN SFP+ , 1 x USB Type A , 1 x
- Power Device
- Internal power supply
- Installed Qty
- 1
- Power Provided
- 500 Watt
- 459 Watt
- FCC Class A certified, UL, cUL, GS, RoHS, WEEE, REACH, ICES Class A, NRTL, VCCI Class A, EAC, CCC Class A, FDA 21CFR1040.10, ACMA, FDA 21CFR1040.11, RCM Class A
- 43.2 cm
- 25.4 cm
- 4.45 cm
- 4.17 kg
- Limited warranty - parts - lifetime
- 0 °C
- 45 °C
- 95%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 65 °C
- Humidity Range Storage
- 85%
