Dell N1108T 8-port Managed Gigabit Ethernet Switch
Quicklinx: F6PHWS00 Mfr#: 210-AJIW
The N1100 switch series offers a power-efficient Gigabit Ethernet (GbE) network-access switching solution with integrated 1GbE and 10GbE uplinks. With high-performance capabilities and wire-speed performance, utilizing a non-blocking architecture to easily handle unexpected traffic loads, the switches offer simple management and scalability via a 1Gbps (full-duplex) high availability stacking architecture that allows management of up to four switches from a single IP address.
  • Robust security
    Equipped with AES, SSL, and TLS 1.0 encryption algorithms, the Dell Networking N1108T-ON ensures secure data transmission across the network, safeguarding sensitive information against unauthorized access.
  • High capacity networking
    With support for up to 16,000 MAC addresses, 512 VLANs, and advanced Quality of Service (QoS) features, this switch is designed to handle high volumes of traffic, ensuring efficient data flow and prioritization across the network.
  • Versatile connectivity
    Featuring 8 Gigabit LAN ports with RJ-45 connectors and 2 additional Gigabit SFP ports, the Dell Networking N1108T-ON offers flexible connection options for a wide range of devices, supporting diverse networking requirements.
  • Advanced management features
    This switch supports a comprehensive suite of management protocols, including SNMP, RMON, and SSH-2, enabling efficient network management and monitoring for optimized performance.
  • Durable and compliant
    Housed in a rack-mountable form factor and compliant with numerous standards including FCC Class A and RoHS, the Dell Networking N1108T-ON is built for durability and adherence to global regulations.
Dell Networking N1108T-ON - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x Gigabit SFP
Performance
Switching fabric bandwidth: 24 Gbps , Forwarding performance: 18 Mpps
MAC addresses: 16000 , Aggregated links (dynamic): 144 , LAG groups: 64 , Queues per port: 8 , VLANs supported: 512 , ARP entries: 2048 , NDP entries: 400 , Max ACL rules system-wide: 4000 , ACL: 100 , Maximum ACL rules per interface (IPv4) ingress rules: 1023 , Maximum ACL rules per interface (IPv4) egress rules: 1023 , Maximum ACL rules per interface (IPv6) ingress rules: 1021 , Maximum ACL rules per interface (IPv6) egress rules: 253
MAC Address Table Size
16000 entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 2, SNMP, RMON, Telnet, HTTP, TFTP, SSH-2
Layer 2 switching, MDI/MDI-X switch, auto-negotiation, port mirroring, IP address filtering, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, Remote Switch Port Analyzer (RSPAN), Management Information Base (MIB), dual firmware images, redundant fans, MAC and IP-based ACLs support, Time-controlled ACLs support
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, ANSI/TIA-1057, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.3ax
21.6 cm x 25.4 cm x 4.45 cm
1.6 kg
Enclosure Type
Subtype
Gigabit Ethernet
Ports
Performance
16000 entries
Routing Protocol
Encryption Algorithm
AES, SSL, TLS 1.0
Authentication Method
RADIUS, TACACS+, LDAP
RAM
1 GB
Flash Memory
1 GB
8 x Gigabit LAN RJ-45 , 2 x Gigabit LAN SFP , 2 x Gigabit LAN RJ-45 management , 1 x USB Type A , 1 x
Internal power supply
Installed Qty
1
Power Provided
24 Watt
FCC Class A certified, UL, cUL, GS, RoHS, WEEE, REACH, ICES Class A, NRTL, VCCI Class A, EAC, CCC Class A, FDA 21CFR1040.10, ACMA, FDA 21CFR1040.11, RCM Class A
21.6 cm
25.4 cm
4.45 cm
1.6 kg
Limited warranty - parts - lifetime
45 °C
95%
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Humidity Range Storage
85%
