Dell 8GB Certified Memory Module - 1RX8 UDIMM 2400Mhz
Quicklinx: DQPDWS00 Mfr#: A9321911
Dell 8 GB Certified Replacement Memory Module for Select Dell Systems - 1Rx8 UDIMM 2400MHz.
Dell - DDR4 - module - 8 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Single rank, unbuffered
Voltage
1.2 V
DELL A9321911
Pricing Type
Upgrade
8 GB
Upgrade Type
System specific
DELL A9321911
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Non-ECC
Module Configuration
1024 x 64
Chips Organization
X8
Voltage
1.2 V
Pricing Type
Upgrade
