Kingston 16GB DDR4 2666MHz ECC Dual Memory
Quicklinx: DQQ3WS00 Mfr#: KTD-PE426D8/16G
Kingston DDR4 16 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V registered ECC for Dell EMC PowerEdge C6420, FC640, M640, R440, R540, R940, T440; Precision 5820, 7820, 7920
Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19
Dual rank, registered
Voltage
1.2 V
Lead Plating
Gold
DELL A9781928
Limited lifetime warranty (Russia - 10 years)
Dell PowerEdge C6420; Precision 5820 Tower, 7820 Tower, 7920 Rack, 7920 Tower
16 GB
Upgrade Type
System specific
DELL A9781928
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL19
ECC
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
Dell PowerEdge C6420 , Dell Precision 5820 Tower, 7820 Tower, 7920 Rack, 7920 Tower
