Kingston 64GB DDR4-2666MHz LRDIMM Memory
Quicklinx: DQQLWS00 Mfr#: KTD-PE426LQ/64G
Kingston DDR4 64 GB LRDIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V Load-Reduced ECC for Dell EMC PowerEdge C6420, FC640, M640, R440, R540, R640, R740, R940, T440; Precision 7920
Kingston - DDR4 - module - 64 GB - LRDIMM 288-pin - 2666 MHz / PC4-21300 - LRDIMM
Memory module
64 GB
Memory Type
DDR4 SDRAM - LRDIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19
Quad rank, Load-Reduced
Voltage
1.2 V
Lead Plating
Gold
DELL A9781930
Dell PowerEdge C4130, C4140, C6420, FC430, FC630, FC830, M630, M830, MX740c, MX840c, T630; Precision 7920 Rack, 7920 Tower
64 GB
Upgrade Type
System specific
DELL A9781930
DRAM memory module
DDR4 SDRAM
LRDIMM 288-pin
Speed
Latency Timings
CL19
ECC
Module Configuration
8192 x 72
Voltage
1.2 V
Lead Plating
Gold
Dell PowerEdge C4130, C4140, C6420, FC430, FC630, FC830, M630, M830, MX740c, MX840c, T630 , Dell Precision 7920 Rack, 7920 Tower
