Kingston 16GB DDR4 2666MHz ECC Memory
Quicklinx: DQQ5WS00 Mfr#: KTH-PL426/16G
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 1333MHz
Data Integrity: ECC
£187.11 ex VAT
£224.53 inc VAT
Kingston DDR4 16 GB DIMM 288-pin 2666 MHz / PC4-21300 CL19 1.2 V registered ECC for Dell EMC PowerEdge C6420, FC640, M640, R440, R540, R940, T440; Precision 5820, 7820, 7920
Kingston - DDR4 - module - 16 GB - DIMM 288-pin / PC4-21300 - registered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2666 MT/s (PC4-21300)
Latency Timings
CL19
Registered
Voltage
1.2 V
Lead Plating
Gold
HP 815098-B21
Limited lifetime warranty (Russia - 10 years)
HPE Apollo pc40, sx40; Cloudline CL2100 Gen10, CL2200 Gen10, CL2600 Gen10, CL3150 Gen10; ProLiant DL160 Gen10, DL325 Gen10, DL360 Gen10, DL380 Gen10, DL385 Gen10, DL580 Gen10, ML110 Gen10, ML350 Gen10, XL170r Gen10, XL190r Gen10, XL230k Gen10, XL270d Gen10, XL450 Gen10; Synergy 480 Gen10, 660 Gen10
16 GB
Upgrade Type
System specific
HP 815098-B21
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL19
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
HPE Apollo pc40, sx40 , HPE Cloudline CL2100 Gen10, CL2200 Gen10, CL2600 Gen10, CL2600 Gen10 Premium, CL3150 Gen10 Base , HPE ProLiant BL460c Gen10, DL160 Gen10, DL160 Gen10 Base, DL160 Gen10 Entry, DL160 Gen10 SMB, DL325 Gen10, DL325 Gen10 Entry, DL325 Gen10 Performance, DL325 Gen10 SMB Solution, DL360 Gen10, DL360 Gen10 Base, DL360 Gen10 Entry, DL360 Gen10 High Performance, DL360 Gen10 Low, DL360 Gen10 Performance, DL360 Gen10 SMB, DL360 Gen10 Solution, DL380 Gen10, DL380 Gen10 Base, DL380 Gen10 Entry, DL380 Gen10 Entry SMB, DL380 Gen10 for Cohesity DataPlatform, DL380 Gen10 High Performance, DL380 Gen10 Network Choice, DL380 Gen10 NVMe All Flash Server for Datera, DL380 Gen10 Performance, DL380 Gen10 SMB, DL380 Gen10 SMB Networking Choice, DL380 Gen10 Solution, DL385 Gen10, DL385 Gen10 Base, DL385 Gen10 Entry, DL385 Gen10 High-Performance, DL385 Gen10 Performance, DL385 Gen10 Solution, DL560 Gen10, DL560 Gen10 Base, DL560 Gen10 Entry, DL560 Gen10 Performance, DL580 Gen10, DL580 Gen10 Base, DL580 Gen10 Entry, DL580 Gen10 Performance, ML110 Gen10, ML110 Gen10 Entry, ML110 Gen10 Performance, ML110 Gen10 Solution, ML350 Gen10, ML350 Gen10 Base, ML350 Gen10 Entry, ML350 Gen10 High Performance, ML350 Gen10 Performance, ML350 Gen10 SMB, ML350 Gen10 Solution, ML350 Gen10 Sub-Entry, XL170r Gen10, XL190r Gen10, XL190r Gen10 for HPE Ezmeral Container Platform, XL230k Gen10 Compute Tray, XL270d Gen10, XL270d Gen10 for HPE Ezmeral Container Platform, XL450 Gen10 , HPE Synergy 480 Gen10 Base Compute Module, 480 Gen10 Compute Module, 480 Gen10 Entry Compute Module, 480 Gen10 Performance Compute Module, 480 Gen10 Premium Backplane Compute Module, 480 Gen10 Standard BackPlane Compute Module, 480 Gen10 w/o Drives Compute Module, 660 Gen10 Base Compute Module, 660 Gen10 Compute Module, 660 Gen10 Entry Compute Module, 660 Gen10 Performance Compute Module, 660 Gen10 Premium Compute Module
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 1333MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL19
Standard: PC4-21300
Brand: Kingston
